way to 'force' start the motor? [kickstart broke]
Posted: Sat Oct 13, 2007 5:44 am
Hi!
The start button never worked, so I always used kick start, but yesterday thanks to the cheap aluminum case, the kick start broke off. Since there's nothing I can do about the kick start, I tried to figure out whats wrong with the start button. I can hear the click when I press it.
Broken kick start:
Spark Plug:
So I took out the spark plug, it was dirty, I took a sand paper to remove all the crap, but still the spark plug doesn't spark when I press the button. So I went to two auto part stores, nether one of them had my spark plugs.
So here I am: Kick start broken, start button doesn't work, the 'running with the bike' startup doesn't work ether. So my question is this, is there any other way how to start up the motor? I even wrapped around string around the motor's gear and then pulled the string out, but no success. Any suggestions?
EDIT: OK, I just bought a new spark plug, plugged it into the wire, but I don't see any sparks when I hit the button, so I guess there's something wrong with the electronics too..
Broken kick start:
Spark Plug:
