Honda VT750 ignition pulses for aftermarket tach
honmuddog
#1 Unread post by honmuddog »
Good day gent's & ladies of course,
I would like to ask you riders for a fresh mind & tech wisdom. I would call manufactuer's tech line but they are shut down for Thanksgiving wknd, Aargh !
I recently acquire a 01 VT750DC & because it has no tach, I've purchase a "TrailTech" Vapor ride computer with bar graph & digital tach and keeps track of a multitude of info. After alot of button pushing trying to set computer for ignition pulses per revoluion {ppr} I'm frustrated & feel like a idiot/dweeb. :frusty:
Tach pick-up/sensor wire is wrapped around one spark plug lead wire,{10 wraps as instructed} It's reading the pulses but apparently reading too many pulses, possibly from close proximity to other lead going to same cylinder but second spark plug. But in my understanding, timing/trigger signal for coil is going to send pulse down both wires at same time when coil fires.
Manual states that majority of vehicles {four-stroke engine} are 1 ppr, while two strokes use 2 ppr setting {duh! easy enough} Neither setting is displaying an accurate rpm via my hand held digital tach/test meter.
What I seek is the "yoda" on this honda ignition system. I realize that maybe each coil {one coil for two spark plugs in each v-twin cylinder} may fire at combustion & exhaust stroke.
Does anybody have a solid lead/clue on what I'm doing wrong or overlooking/under-thinking? These computers are reliable & accurate not "chinese junk" as I have them on my offroader & dual-sport scoots. Somebody please slap me around with any wisdom/experience that you have stored in your RAM, mine has got run over by a Dodge truck & don't function as it should.
Thanks for any info & your time sharing the knowledge, hoping you all had a great thanksgiving w/family & friends, hoping that you always be thankful for those who make it possible, :USA:
JP
mydlyfkryzis
Years Riding: 42
#2 Unread post by mydlyfkryzis »
Not sure for your bike, but my 750 Nighthawk has 2 coils, 2 cylinders share a coil. So I have 2 PPR. One cylinder has a wasted spark.
My CB360 has 2 coils, one per cylinder and has 1 PPR.
I suspect you have 2 PPR.
I don't have a electrical schematic for your bike, but I bet there is a tach output on the CDI module. Maybe someone on this site has an idea...
Richard - Fully Dressed
Naked 1976 Honda CB360T
