How often do you change the oil.
zenman
#1 Unread post by zenman »
I thought every 3000 miles. like a car. My rider friend says every 10000 to 15000 miles. Also, if I change it myself, do I have to use motorcycle oil or can I use regular car oil?
I bought 3 quarts of motorcycle oil for my GZ250 and a filter, and the total was $35. I can get it done for me for $50.
niterider
#2 Unread post by niterider »
For my vulcan the manuel says every 6,000 miles.
And it calls for SAE 10W40 or 10W50 cold weather
And SAE 20W40 or 20W50 for warm weather.
As for miles I usually go 1,500 to 2,000. And use the 20W50 year round.
BTW I use castrol gtx.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
Skier
#3 Unread post by Skier »
There's plenty of threads about this. Check the search function.
I don't like faking it, so I get my oil analyzed at every oil change. It's the only way to be truly sure how your oil is doing.
Gadjet
Real Name: Owen Clark
Years Riding: 19
#4 Unread post by Gadjet »
I change my oil every 3000 miles (5000km) and I only use bike specific oil or Shell Rotella T.
Do not use car oil in your bike - you'll wreck your clutch
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
Skier
#5 Unread post by Skier »
Gadjet wrote:Do not use car oil in your bike - you'll wreck your clutch
Not true.
#6 Unread post by Wrider »
Not true.
Only true in a way... If you use car oil with a detergent it'll let it foam up easier, and also because of the modern anti-friction additives, it can make your clutch plates slip. The anti-friction additive gets into the friction material and even after you change your oil again it'll make your clutch slip.
Oh, and about your friend's 10-15K mi between changes... :laughing: Honestly if he's doing that he's hurting his motor quite a bit.
BikerEd
Oil
#7 Unread post by BikerEd »
The guy that changes his oil every 10-15 K Mi. must change his bikes every year. That will kill an engine. My oil gets changed at 3000 Klm.- 1800 Mi. Had a 750 Honda for 6 years,never took oil. Used synthetic oil in my Yamaha 1100 once , clutch slipped like h#&*. Ok when i went back to Bike Oil.
Ride careful, you'r dead a long time .
-Curly-
#8 Unread post by -Curly- »
My owners manual says every 4,000 miles and filter every 8,000 miles. I just change them both every spring.
2006 Yamaha VStar Custom
Green Knights Motorcycle Club
"Freedom Through Service"
slimcolo
#9 Unread post by slimcolo »
Harley manual for my old FLH says 1000 miles my BMW says 4000
jimyed
#10 Unread post by jimyed »
Not true.
Could you expand on that? Everything I've raed suggests that the friction modifiers in modern car oils are bad for bike clutchs (Ok may not wreck them but are not good).
I change my oils every 5000KM or so. I use Semi Synthetic Motorcycle oil.
I change the Filter every time. And i do it myself.
“Motorcycle racing should be the domain of hairy men with death wishes that perform magical displays of ballet with fire-breathing beasts hell-bent on killing them at the first opportunity."
- Franz
