what carbs work on a cb360?
corey
#1 Unread post by corey »
hey, i've decided the carbs on a 75 cb360 i just bought are too shot to put any real effort in to rebuilding. does anyone know how i can figure out what carbs will also fit on my bike, preferably carbs that improve performance? thanks!
beat it to fit, paint it to match
#2 Unread post by Johnj »
Check the Mikuni site yet.
corey
mikuni vm32mm
#3 Unread post by corey »
huh... so, the mikuni vm32mm kit fits my bike. and about 20 other bikes, but the price is slightly different for each bike. what exactly does 32mm refer to? can i assume that with proper tuning, any 32mm carb will work on my bike?
thanks!
#4 Unread post by Johnj »
The 32mm is the size of the opening. Any carb will work, if you get the jetting correct for it. Your best bet is to stick with the recommendations of the manufacturer as they've be at this for a long time.
corey
#5 Unread post by corey »
so, the stock carbs work better than the mikuni carbs? mikuni claims to increase performance.
fireguzzi
Real Name: Trevor
#6 Unread post by fireguzzi »
If Mikuni says you can use em, it's a safe bet you can use em. If they say they are an upgrade from OEM, they probably are.
corey
#7 Unread post by corey »
all right then, it's settled! mikuni carbs for my bike. thanks guys!
oh, by the way, are flat sliders really that much better?
mydlyfkryzis
Years Riding: 42
#8 Unread post by mydlyfkryzis »
Really depends on what you mean by better.
You will also have to deal with adapting the throttle linkage to the mikunis.
I would check E-Bay for a serviceable set.
If your diaphragms are intact, I would rebuild the existing carbs. you can still get rebuild kits.
Richard - Fully Dressed
Naked 1976 Honda CB360T
corey
mikunis
#9 Unread post by corey »
well, by better, i mean the mikuni website offers "better performance due to less restricted flow". i'm always looking for more efficient performance. adapting throttle linkages won't be a problem, as i'm not using the original throttle linkages anyway. what i'm hoping for is something simpler, more efficient, and an increase in throttle response would be great. are there any downsides to mikuni flat slides that i should know about? thanks for your help!
