Traffic signal tripping device
Posted: Mon May 30, 2005 10:32 am
Anyone tried this and determined that it actually works?
http://www.jcwhitney.com/autoparts/Prod ... 11/s-10101
I'm skeptical.
The fact that an object is magnetized shouldn't increase its effect as a concentrator of magnetic lines of flux coming from an current loop. In fact, if it's magnetized enough it will be saturated and its ability to do so will be limited.
What it might do is, as you move into the loop, it might induce an electromotive force in the loop. But I don't know if the loops are set to detect both increases and decreases in their loop voltage, so it might not work on loops polarized the wrong way (though it might if they are standardized). And you'd have to be moving, so the changing magnetic flux from this device could create the EMF in the loop.
On the other hand, it's so close to your bike that most of its magnetic lines of flux will be concentrated in your bike's ferrous parts, leaving very little to reach down into the ground to interact with the loop.
So, from a theoretical standpoint, this thing looks like bollocks. But maybe adding an extra slug of a high-permeability material to your undercarriage lets the loop's magnetic field "see" you better. For that, this thing is awfully small, although some of the newer supermagnetic materials are pretty impressively much stronger than the old ones...
See why I need objective, empirical data? And a long ride in the sunshine followed by a cool margarita in the shade with my dog? And another girlfriend?
I'm skeptical.
