I bought the bike knowing that it had some carb issues, and got the guy to knock $200 off the price for a carb clean. Which, of course, I'm going to try to do myself before I take it to someone. I have a lot of air-cooled auto engine experience. Never been great with carbs though. Haven't gotten to it yet, but I'm worried it's not a simple carb problem... Sorry, this is going to be lengthy!
Here's what's happening:
when the bike is cold- (particularly when the weather is cold)
difficult time starting
under 1/3 choke applied = under 1k rpm idle, dies (seems like the choke is REALLY sensitive. On or off.)
over 1/3 choke applied = 5k rpm idle
blip throttle, bike dies
gradual throttle bike sputters and jerks, then revvs up to 3k
If I really fiddle with the throttle I can find a tiny sweet spot where it sits at 2500rpm until it warms up a bit. Then it still sputters and jerks and dies a few times as I pull away from the first few stop signs. Then I have to revv it pretty good for a few stop signs but I don't like putting a cold bike up to 6-7000 rpm just to warm it up quickly! Especially to a bike that I'm pretty sure is due for a valve adjust...
when the bike is hot-
rolling off the throttle to shift, rpm blips on its own(6k)
coming to a stop, rpm hangs around 3k, 4k
let the clutch out just enough to pull the rpm down below 3k, and idle drops to 1200, then idles nicely @ 1200-1500
makes power from 5k rpm+, otherwise lugs pulling away from a stop
Also sounds a bit like there's pinging in the exhaust, ticking sound from the front of the motor when I roll off the throttle at high-ish rpm
I already tried pulling the tank and checking for vacuum leaks. I sprayed all around the boots that I could find with WD40 while the bike was running to no result. I checked the cables, including the choke and none of them seem to be sticking or binding. Everything is snapping back into place like it seems like it should. I also ran the better part of a pint of seafoam through it (mixed in the gas) and it seems to have gotten it to idle fine when it's hot as I described above as a result. Next weekend I'm planning to pull the carbs and clean them (after my Clymers manual comes in the mail). Any theories as to what's going on here? I'd pin it on the mixture or the idle set screw except that it idles nicely after it's hot (provided I pull the the rpm down with the clutch at every stop)
I think my plan for now is to pull the carbs and have a look, then give it over to a mechanic. Any ideas? Should I play with the mixture? or the idle speed screw?
I also can't seem to find a carb rebuild kit for an '01 GS500 so if anyone has a lead please let me know, otherwise I'm going to be re-using the rubber!
Thanks in advance!
