Reverse gear kit
moran4x4
Reverse gear kit
#1 Unread post by moran4x4 »
In Europe, they are using a reverse gear kit on car powered by motorcycle engine.
Can somebody help locate the kit??? :frusty:
Heath Robinson or Fred Flinstone ( bedrock kit )
Thanks
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#2 Unread post by Gummiente »
It would help to know what kind of bike or bike motor you're talking about. The only European bike I know of that uses a car engine was made in France many years ago... can't remember the name but it used a Citroen 2CV engine - and it had a reverse gear.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
Macka
#3 Unread post by Macka »
The shed where I park my bike is at the bottom of a hill in my backyard...i used to wish for a reverse gear on my bike, 'cause it's hard to pull a bike backwards and uphill at the same time!!!
Then, I got the bright idea to back it in to the shed when parking...genius!! :laughing:
2005 Suzuki Katana 750
CentralOzzy
Real Name: AL
Years Riding: 42
#4 Unread post by CentralOzzy »
I woulda kept that quiet if I was you. :|
moran4x4
Re: Reverse gear kit
#5 Unread post by moran4x4 »
moran4x4 wrote:In Europe, they are using a reverse gear kit on sport race car powered by motorcycle engine.
Thanks
Nibblet99
#6 Unread post by Nibblet99 »
I believe some goldwings have reverse gears, it may be worth looking at parts for them, and seeing if you can adapt them. Although.....
1) I'm not sure about the idea of driving a chain backwards (It'll probably be alright if your bike uses pull backs, but I've heard that some bikes have auto tension adjusters.
2) the new gear box may be larger
3) wouldn't it be easier to back the bike down the hill, and then drive out of your garage forwards.
moran4x4
Reverse gear
#7 Unread post by moran4x4 »
They are using them on LOTUS replica.............. :wink:
Who makes the reverse gear kit ( like a small gearbox)????
Thanks
XJRJohn
#8 Unread post by XJRJohn »
goldwings dont actually have a reverse gear as such,just a switch to run the starter motor in reverse.or so im told.
ive seen the hyabusa motor used in a three wheel type thing that leans into corners like a bike,dont know if its got a reverse though.xjrjohn
biking isnt a matter of life or death,its far more important(bill shankley,well almost)
