yamaha '78 xs400
Posted: Wed Mar 16, 2005 6:47 am
Hi,
Im relative new to multi-cylinder four strokes. I bought a '78 yamaha xs400, according to haynes manual and a complete comparision of the wiring diagram i am led to believe its a xs400F / xs4002F.
Now, WHERE ON EARTH do I plug in a carb syncing device?? Also one of the carbs (left-side) has a black 'condom' on the vacuum intake nipple, there was a lesser-gauge black rubber line just hanging from the gas tank petcock, the manual says this is the vacuum (something, i forget exactly what) where does the other end of this pipe go? the other carb nipple???
Also, there is a connection between the two carb air-intake hoses. it has another small rubber tube coming out of it.. but just left hanging. what is this??? Check out the top view i've drawn below
_______
L.Carb -> (_)--------|______/ <-L. Air Filter
RUBBER PIPE LEADS NOWHERE! -> ---- | <- Balancing Hose??
| ______
R.Carb -> (_)--------|______\ <-R. Air Filter
There seems to be an inlet/outlet on the engine that this rubber pipe seems to lead into, but im not sure.
Any help is greatly appreciated.. thanks
_______
| ______
