Vibration in bones
Posted: Tue Jul 01, 2008 10:19 am
by Dragon on Wheels
Everytime I let the bike go in the higher rpms (8000 +) for extended periods of time(about 40 minutes to 1 hour), my bones in my hands and wrists feel like they are tuning forks that were just struck. This pretty much only happens when I have to take a highway since I don't rev up so high otherwise. The feeling generally lasts maybe 10-20 minutes or so, but is very uncomfortable. Has anyone else had this feeling before? Is there any way to dampen the vibrations?
Posted: Tue Jul 01, 2008 11:09 am
by Skier
You're gripping the bars too hard or putting too much weight on your hands. Use your lower back muscles to keep yourself upright, not your hands.
Posted: Tue Jul 01, 2008 3:03 pm
by Brackstone
Skier wrote:You're gripping the bars too hard or putting too much weight on your hands. Use your lower back muscles to keep yourself upright, not your hands.
+1
I do this with my Shiver because it's a totally naked bike. So when I grip it I GRIP IT.
I finally realized I need to loosen up and when I did it helps a lot. I still tense up from time to time but my elbow reminds me with some pain
Re: Vibration in bones
Posted: Tue Jul 01, 2008 3:11 pm
by HYPERR
Dragon on Wheels wrote: Is there any way to dampen the vibrations?
Make sure the carbs are sync'd. Is one of your mirrors blurrier than the other?
Bar end weights may help also.
Posted: Tue Jul 01, 2008 4:20 pm
by olebiker
Get a bigger bike.
Posted: Wed Jul 02, 2008 9:40 am
by RegalSwan
A pair of gloves with gel palms will also help. Mine greatly reduced the numb feeling after long rides, but I don't know about a tuning fork...
Posted: Wed Jul 02, 2008 5:43 pm
by Dragon on Wheels
Thanks everyone! I'm gripping the bars too hard. I'm actually bent a bit forward when I'm on the highway because if I sit up straight the wind blasts right into me which probably causes me to lean into my wrists. I sit up straight when I'm on local roads so it doesn't happen. I'll have to remind myself to keep the pressure off.
Posted: Wed Jul 02, 2008 11:32 pm
by Wrider
Ah, well that'll do it! Use your legs more or lean on the tank... Usually helps me when I'm on a sportbike (with a stomach like mine the wrists don't like sportbikes!
Posted: Thu Jul 03, 2008 1:25 am
by storysunfolding
I agree that you need to loosen up, but Grip puppies are $8 and help as well.
