Carb adjusting ??
Pegleg
Carb adjusting ??
#1 Unread post by Pegleg »
I have a 97 Kawasaki 800 Vulcan. The grandkid found the knob that adjusts the carb. :x How would I go about getting this thing back into adjustment? Not sure weather to turn clockwize or counter clockwize to start.
Pegleg
#2 Unread post by Johnj »
What is the result, more rpms at idle or less? If you turn it clockwise does it get better or worse?
ofblong
Real Name: Ben
#3 Unread post by ofblong »
could be like me and have a broken spring but im too lazy to replace it lol. Your manual should tell you which way to go.
96' Honda Shadow Deluxe VLX
Pegleg
#4 Unread post by Pegleg »
The motor is running very rough. I turned the knob all the way clockwize then turned it back a quarter turn. I got it started but the front cylinder was loadin up. It seemed to get better the more I turned it counter clockwize. It still idles rough but smooths out at higher RPM's.
young Cruiser
#5 Unread post by young Cruiser »
Personally, I would ask the Grandkid :)
I have a 97 Vulcan 500 LTD and the manual says:
Start the engine & warm it up thoroughly.
Turn the adjusting screw until idle speed (1,300 +/- 50 rpm) is correct.
Open & close the throttle a few times to make sure the idle speed is within the specified range. Readjust if necessary.
Doesn't say which direction to turn.:?
Also, how would you know the correct rpm for your bike, you got a tachometer?
Guess you'd just have to feel it out from how you know your bike feels and sounds.
97' Vulcan 500 LTD
00' TW200
Still trying to decide what I love most... Marriage or my Bikes!
ssshhhhh don't tell the wife.
honda750
sounds
#6 Unread post by honda750 »
sounds to me like you need to make sure your low speed jet isnt clogged.
99.99% of the time clockwise increases the idle, counterclockwise decreases
you really just got to feel it and hear it.
Opium Rehab Forum
