cb360t headlight, horn, start
Posted: Mon Aug 25, 2008 5:03 am
by stanwich
hey guys! anyone have this prob. when keys turned to ignition there is no power to my light and electric start or horn. fuse is good. trying to find the headlights control module. any ideas?? its a 74
Posted: Mon Aug 25, 2008 5:58 am
by Johnj
Take your meter and read across the battery. Red lead to positive and black to negative. What do you read?
Posted: Mon Aug 25, 2008 10:19 am
by stanwich
12 v . new battery !! click key over once and I get power to tail light and signals but no headlights or electric start. turn key to ignition and I lose the signal lights ect. looking at the wiring diagram it seems to be an issue with the headlight control module but I can't seem to find it.
Posted: Tue Aug 26, 2008 10:56 am
by insaneman_12
Test your ing. switch
Posted: Sat Aug 30, 2008 6:35 am
by mydlyfkryzis
The Right switch pod on the handlebars is the headlight control.
The wires come out of the pod and end up under the fuel tank. there is a big rubber cone covering all the connections.
My pod fell apart inside (the plastic inside the switches dissolved). I would check that first.
Get a wiring diagram. From here:
http://oldmanhonda.com/MC/MC.html
Go to archive wiring diagrams and pick your model.
Good luck.
Posted: Thu Sep 04, 2008 5:17 am
by Fargo360
I bet you a dollar that you have crossed wire harnesses.
Betting on the switch
Posted: Thu Sep 04, 2008 12:16 pm
by RoboChief
Check the poles across the switch. You should get near 0 Ohms across the Battery in and Starter out poles, with the ignition in the start position.
wow, its been awhile since ive checked replies
Posted: Mon Nov 03, 2008 6:18 pm
by stanwich
74 cb360t , thanks for the advice guys, i still have a question though, looking at the wiring diagram for this bike at
i see the headlight control swithch right next to the starter switch, obviously this is not the headlight, highbeam and turn signal, where is this control switch on the bike?? ill check opics of similar bikes to make sure it wasnt removed but im sure it cant be located on the handlebars, this is the only part that confuses me,
