Page 1 of 6
"Oops", how do I get out of this pickle?
Posted: Sat Sep 06, 2008 7:32 am
by ErnCol
I'd go to the dirt bike forum, but I'd rather have you experienced street bike riders tell me how you get out of those situations in the loose dirt/gravel/mud, etc that you should never have gotten into in the first place.
So far, when I've traveled down that nasty dirt road that I shouldn't have on a street bike with street tires, I've managed to just power out and occasionally put my feet down for balance/stability.
You know those tempting roads that are all nice hard packed dirt until you round that corner up the hill and have to turn around?
Any tips that dirt bike riders use that can be used for heavier bikes...video references on UTube for instance? No dirt bike experience here.
Yeah, I know somebody is going to say..."stay on the pavement"...but what if you are run off the road and have to get out of the soft stuff?
Be nice. :frusty:
Posted: Sat Sep 06, 2008 9:27 am
by Skier
Be smooth and practice. The best practice is taking those roads on a dirt bike to build confidence then take your road bike on the same surfaces.
I did about 1,000 miles of road with the following surface on my street bike with street tires:
Any bike can do it, you just need practice.
Posted: Sat Sep 06, 2008 10:12 am
by ofblong
I just take longer to do things like brake/slow down.
Posted: Sat Sep 06, 2008 11:18 am
by slimcolo
Be careful about using front brake especially going downhill. Front end will wash out using brakes like on the macadam. Keep up the revs so bike is in power band.
There is an old dirt bike saying "when in doubt crank it out" meaning that cracking the throttle will often get you out of hairy situations better than brakes, a controlled spin is better than a un-controlled slide.
Almost nothing reacts the same on dirt as on pavement, gravel is yet another thing entirely.
KNOW YOUR SKILL LEVEL, you're not Malcolm Smith or Chris Blas so don't try to ride like them, If you were that good you would already be a pro.
Take the MSF Dirt Bike School
http://www.dirtbikeschool.org/
http://www.dirtbikeschool.org/downloads/MSF_TnPG.pdf
Try reading up on off-road techniques and of course PRACTICE PRACTICE PRACTICE
http://http.vitalstreamcdn.com/msfusa_v ... 604-21.wmv
Posted: Sat Sep 06, 2008 2:52 pm
by Skier
slimcolo wrote:Be careful about using front brake especially going downhill. Front end will wash out using brakes like on the macadam. Keep up the revs so bike is in power band.
Lot of good info here, but remember to be careful about using the front brake, but don't avoid it.
Posted: Sat Sep 06, 2008 4:10 pm
by ErnCol
Thanks for all the info and tips.
A little "schooling" sounds like a good idea.
And the neighbor owes me a favor and owns a dirt bike that he has offered to loan me. :wink:
Posted: Sun Sep 07, 2008 11:48 am
by follow
You see no one gave you a hard time....I happen to know alot of people who live down dirt roads, so taking a bike to visit or for them to just get home in enevitable.......Like slim said easy on the front brakes, I also find going too slow can cause issues. :wink: have fun!!
Posted: Thu Sep 11, 2008 5:53 am
by Zagnut
Do things slow and easy. If your going straight, not too slow...a little speed will give you a bit more stability than going too slow....kinda ride over the gravel rather than through it.
If you are turning, do it slow and easy and maybe even keep your feet down or at least ready to be put down quickly as stabilizers.... and dont even think about using the front brake!...back brake only!... Grabbing front brake in gravel will drop you like a hot potato.
Posted: Thu Sep 11, 2008 8:39 am
by Skier
Zagnut wrote:Do things slow and easy. If your going straight, not too slow...a little speed will give you a bit more stability than going too slow....kinda ride over the gravel rather than through it.
If your tires don't have enough traction to keep the motorcycle upright, how will your feet? Do you have the leg strength to counteract both gravity and the momentum the bike has developed before you can react to it falling?
Avoiding the front brake is silly. Grabbing the front brake on any surface will "drop you like a hot potato." Use it but use it properly.
Posted: Thu Sep 11, 2008 11:37 am
by ofblong
Like skier said NOT using the front brake on any surface is stupid. using only the back brake can drop you like a hot potato as well.
