New rotors? was battery question.
Posted: Fri Sep 19, 2008 3:41 am
This all applies to my 1983 CB550 nighthawk.
Ok, so I removed the stator and took it in to get a replacement. The shop tested it or me and found everything in working order. I have done the tests for the regulator/rectifier and it seems to be good.
My manual tells me that the only way to test the rotors is to swap them out with new ones. should I not be able to tell if these rotors are magnetized without swapping them?
The rotors that I have currently are original to the bike and do not seem to have any magnetic "charge" at all. When I took the stator in I was shown used rotors that they would sell me as a replacement but these also had no magnetic field to them.
How can I tell without shelling out $80 bucks for used rotors that may or may not be good?
And am I even on the right track??? I'm still only pulling 13.5 volts out of the charging system and I need help.
Tx
Waylander
Tx
Waylander
