float gum up and fuel q's
Posted: Wed Oct 08, 2008 4:26 am
Trouble keeping my float from gumming up. Told to drain carbs when bike sits. One carb screw is on located my Vulcan 500 so that I can not position my hex key in a straight on position to loosen. Its on the inside side of the bowl. Any clever thoughts?
Also if I want to run the fuel out of the carbs what position should the fuel be in as "on" is supposed to be an automatic shutoff when machine is off. Does that make sense?
