Engine Oil Change : Automotive oil or Motorcycle Oil?
Posted: Sat Jan 03, 2009 1:28 am
Hi,
I've been searching for the best engine oil to use for a my motorcycle, a 125cc 4-stroke SOHC 2 valve commuter bike ( like the one you see in indian movies). Here are the specifications from the manufacturer:
Kawasaki Fury 125 (Kawasaki Athlete in India)
Lubrication System: Forced Wet-Sump
Engine Oil: 10W-40 Multigrade
Type: API SE, SF, SG, SH, SJ, SL, JASO MA
Capacity: 1.1 Liters (1.2 Quarts)
I'm a bit confused because most say automotive oil will do while others say it wont.
People say I should get the same oil as the manufacturer recommended, which is 10W-40, but which brand?
I've heard that I should get something with a high phosphorous ppm rating and a low sulfur rating.
Also I've seen different mileage recommendations on when to change oil and oil filter, like 1000miles, 5000miles, etc.
I'm planning to go with 4000kms (2500 miles), is this ok?
Oh and yeah, some important details I assume you'll ask, what will I use the bike for?
I will use the bike mostly for daily commuting, and maybe circuit or drag racing once in a while (Annual events, etc.)
All parts are stock as of the moment.
Thanks.
Thanks.
