Need to use tread chaser for frame fitting
Posted: Sun Mar 22, 2009 1:25 pm
Kawaski Vulcan 500 LTD EN500CF
I was starting to install a Protac Drivers backrest and one side mounting bolt came out fine and reinstalled fine.
The other side was very hard to remove, I put the bracket on and attempted to reinstall the oem bolt. It was as difficult and turned impossible as the bolt bent.
I have just order (2) bolts (I only need 1) from bikebandit.com but was thinking if I should also run a tread chaser through the frame fitting that the bolt goes into.
I have not rethreaded or chased threads in 25 years. Any suggestions on starting the tool and resistance points ?
How much should I expect to pay (retail price) of the handle and male tread chaser? It is also metric bolt with a 10 mm socket head.
Thanks for any insight you have.
