Charging issues on an 83 cb550. - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
6 posts • Page 1 of 1
waylander
Years Riding: 3
My Motorcycle: 1983 Honda CB550SC
  • Quote
#1 Post by waylander » Sun Apr 19, 2009 10:02 am
Hope someone out there can help me out with cause I just can't figure this one out.
I had charging issues late last year and thought I had tracked it down to the Regulator / rectifier, so I sent away for a new one.
Just finished setting the bike up for this years season but am still only reaching a maximum of 13 volts from the charging system with the new rectifier installed. I had taken the stator in to a local shop last year and their tests said the stator was ok.
I don't know what to check nexxt. :frusty:
My bike is a 1983 CB550SC Nighthawk
Ideas??
Tx Much
Waylander
storysunfolding
Years Riding: 22
  • Quote
#2 Post by storysunfolding » Sun Apr 19, 2009 12:31 pm
You've checked to make sure the battery itself is good right? A bad battery can upset a charging test
My Blog
Grasp life by the handlebars
waylander
Years Riding: 3
  • Quote
#3 Post by waylander » Sun Apr 19, 2009 6:46 pm
I guess I should have mentioned that.
I purchased a new battery late last year (after finding out that the old one was not getting a proper charge). I have kept it in good condition with a decent charger over the winter so I am pretty sure that's not the issue.
Waylander
  • Quote
#4 Post by Johnj » Sun Apr 19, 2009 7:01 pm
Have you cleaned and serviced all connectors in the charging circuit?
waylander
Years Riding: 3
  • Quote
#5 Post by waylander » Mon Apr 20, 2009 12:27 pm
I have cleaned them as best I could. A fine emery board seemed to do the trick but didn't give me any better results. Could it be a bad wire somewhere in the system? I do get consistent results so I don't think that's it but...?
I should mention that the system will build up to 13 volts at around 3000 rpm but does not get any higher than that regardless of the revs.
Waylander
richie
stator
  • Quote
#6 Post by richie » Thu May 28, 2009 8:15 am
im not an expert by no means but ive found that even though your stator is still charging the years will take a toll on the magnetic properties of it and will still work but weak and this will kill even a new bat if you make short trips you know alot of starting and stoping
  • Print view
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
