I just bought a 1974 Honda CB360 project bike
JBCB360
#1 Unread post by JBCB360 »
Hello All,
I'm a new member, new rider, new everything. I found this bike near by and couldn't pass up on it. Only problem is it doesn't run and I've never worked on a bike before. I'd like to gather some suggestions before I go crazy buying parts. ( Like points what are the left and right points) I have little knowledge on bike parts but am willing to learn.
I'd like to bring it back to life and use it as a daily ride for now.
Besides the obvious, what are my main concerns and things that should be brought to my attention to repair.
The gas tank has little surface rust inside. Does it need to be cleaned? What's my best solution. Is there a bike part diagram breakdown anywhere?
I've noticed it's missing the petcock and fuel lines, exhaust is shot, fork seals are a bit leaky, and theres no batter box, and the air filter is junk.
What should be my first steps into attacking this bike/what I should purchase first attempting to start it.
The bike looks good from afar but far from good.
Thanks,
Joseph
#2 Unread post by Johnj »
Nice Ok first off get a manual. Use Google to find a Chilton or a Clymer, but buy a manual. All your answers are in the book. The points are just a switch that tells the coil to spark the plug. The left point, condenser, coil,plug wire, and plug 'fire' the left half of the engine. Petcocks can be found at any of the bike parts places on the web. Fuel line is at the auto parts store. Mufflers can be found on the web. Same with fork seals. The battery box may have you looking at motorcycle salvage yards or getting a parts bike. The air filter can be had on the web.
It looks like the kick start pedal is missing. You might want one of those.
Go take the MSF safety course.
Fargo360
My Motorcycle: 1998 Honda VTR1000 SuperHawk 996
#3 Unread post by Fargo360 »
get a shop manual
that's an actual honda shop manual for the cb360, from honda issued to dealer shops. I have one and its awesome.
Next I'd pull the carbs and do a rebuild and very thorough cleaning. Carb rebuild kit
Also, I'd do a compression test on the engine (if its not seized up) and see if you have good compression, the manual will have what the compression rates should be. I think its like 90/140/160/170/170 (psi). Use the kick start with the compression tester, you should have something like that for each kick (90psi first kick, etc).
Here an ebay link for a battery box and petcock
I'd get some new spark plugs and a battery, if the compression test is good, and you've got your carbs all cleaned up I'd try to fire it up and see if it runs. You might need to work with the floats a bit to get them right and I'm pretty sure you are going to need to get the carbs sync'd up, but the bike should run without a sync, just maybe a bit rough. If you get it running do an oil change. I'd do it after you get it running 'cause if you do it first and you have to tear into the engine, then you wasted an oil change. The filter is inside and doen't really get changed. You can clean it, but its a non disposable centerfugal filter and its inside the engine and is a real piece of work to get at. The manual will explain. Do clean it before you really start to ride though. As for oil, I use mobil 1 10w40. The book says you can use sae30, 10w30 or 10w40. Mine always seemed to run hot on the 30 that was in there, so I went to the 10w40 and that seems to work better.
After the bike runs you can worry about setting the chain tension, new tires, electrical issues, all that other fun stuff. There's a coil power mod that you can do that really helps with ignition. But you can worry about that after the bike is running.
Oh yeah, fork seals
And you can get mufflers from JC Whitney, they aren't quite stock, but they look good and they are WAY cheaper than finding some NOS exhaust.
Have fun! I have been working on my CB360T for almost a year now, its been frustrating at times, but very rewarding when it works out. When I ride around on it I always get compliments on having an old bike that looks good. When working on a bike like this i've found that ebay is your friend, as you can find most of the parts you need on ebay, just be careful. Any other questions just ask...this place is awesome when it comes to help.
1976 Honda CBR360R/T
surfshrink
#4 Unread post by surfshrink »
That is a really good bike. I bought a used one for about $350 when I lived in Connecticut. My car kicked the bucket and I needed cheap transportation. I brought it back to Missouri a few years later and sold it to a friend. He promptly introduced it to the back end of a car. No one was hurt, but it was the end of a really good bike. (I thought I posted this earlier, but I guess I hit the wrong key or something.)
