Starting troubles
Whitetiger018
Starting troubles
#1 Unread post by Whitetiger018 »
I have a VT 1100 Honda Shadow I live in New England Humid Summers. When the engine is sold it'll start fine after I ride and stop it won't start. :x It won't even turn over like a dead Battery, but if I turn the key off and back on it'll start sometimes I have to do that a couple of times. Or I roll the bike back and forth a couple of time then it'll start. :frusty: the battery is fine I checked to see if that was fine or not. Driving me crazy would rather ride than be driven crazy :laughing:
I own a 2000 VT1100 Honda Shadow
I Ride with the Patriot Guard Riders
niterider
#2 Unread post by niterider »
Sounds like the problem is in the ignition switch or you starter brushes are worn down. Hope this helps you.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
