??? about re-gearing a Honda Shadow ACE
Posted: Mon Jun 13, 2005 3:59 pm
by monkers
I have a 2000 Honda 750 Shadow ACE and so far I love the bike with one exception. When riding on the highway (65MPH) the bike seems to be revving pretty high. Can I drop down two teeth on the rear sprocket and take a link out ? It just seems to need another gear on the highway. How badly will this effect my low end? Thanks for the help,
Craig
Posted: Mon Jun 13, 2005 5:31 pm
by Sev
How high is pretty high? I seem to recall that a shadow has a redline somewhere around 8000 to 9000 rpms. My buddy runs his as 140km/h regularly with no adverse affects so far. It's 3 years old now.
Posted: Mon Jun 13, 2005 5:35 pm
by mswarrior
Doesn't taking teeth out raise the RPM?
Posted: Mon Jun 13, 2005 7:39 pm
by BuzZz
On the rear sprocket, adding teeth will raise the rpm needed to hold any given speed. Subtracting teeth will lower the rpm needed to hold the same speed.
On the front sprocket, the opposite is true. More teeth = less rpm
Posted: Tue Jun 14, 2005 5:04 am
by Abner
If you lower you cruising RPMs, I think you will also loose some low end power and torque. But if you do mostly high speed cruising and don't mind losing acceleration power, I guess it would be okay.
Instead of changing the sprokets, you could also get a slightly taller tire, it would have the same effect. Smaller tire, higher RPM but faster accelaration.
You need to add another gear, but the only problem with that is you would need a new transmission. The easiest way to get a new trannie, is to get a new bike. An I know that's expensive
