Turns Over, Doesn't Fire
Posted: Tue May 19, 2009 10:04 am
***I'm posting this in two different sections of the forum to ensure that everyone sees this in hopes that someone out there can help.***
Circumstances: took the bike to my mother's house for several days to store it "safely" while I went on a trip to Palestine. I arrive yesterday to find that the bike just won't start.
*note* I am not mechanically-inclined at all, so any answers will need to be really detailed.
Problem: Turn the key, flip the switch, press the button. Turns over but won't fire. At first I figured it was because it hadn't been run in several days, but I've never had this kind of trouble after even a week of not running.
Problem 2: I figured that maybe... just maybe... the spark plugs might need replacing. Can't find 'em on the bike. Anywhere.
Problem 3: Maybe head gasket needs replacing (so hubby says, but he's gone for several days as well so he can't show me where it's at)? When I try to start it, you can hear a soft but deep "pop" from the exhaust.
Problem 4: My mother had the bright idea of going outside a little while ago and trying to start it for a while, and ended up leaving the keys in and on and ran down the battery. It died after no more than 10 minutes. Is that even remotely normal? If the battery ran down after a mere 10 minutes, is it possible that it just didn't have enough power left to completely start the bike? Or would that not be an issue?
So right now, I have a massive hunk of metal and wires sitting outside with a battery that buzzes at me when I push the starter button and nothing more.
Misc info: it rained the several days I was gone. The bike has about 44k miles on it. The kid who I bought it from probably didn't do much to take care of it. Ran perfectly fine when I last took it for a ride. It's a 1994 FZR600R (as the signature implies). If you need more info, just ask. Will do the best I can to explain.
Thank you very much in advance.
