Handle Bar Grip removal
Posted: Thu Jun 25, 2009 7:35 am
by Chemical Duke
Got a 06 Honda Shadow Spirit 750. I'm trying to replace the grips and can't get them off. Got any ideas or how to's?
Posted: Thu Jun 25, 2009 7:59 am
by Johnj
I used a knife to cut the old ones off. I mix a small amount of dish soap with water, coat the inside of the new grip and the handlebar with the soap solution and slide them on.
Posted: Thu Jun 25, 2009 9:03 am
by Wrider
Johnj wrote:I used a knife to cut the old ones off. I mix a small amount of dish soap with water, coat the inside of the new grip and the handlebar with the soap solution and slide them on.
+1 except I use WD40
Posted: Thu Jun 25, 2009 10:09 am
by Chemical Duke
It worked! Thanks guys for the help. You 2 just made my bike look a little cooler.
Thanks again!
Posted: Thu Jun 25, 2009 7:35 pm
by slimcolo
Gas works too providing you have a metal, not plastic, throttle sleeve.
Posted: Thu Jun 25, 2009 8:07 pm
by BuzZz
I've used everything from spray paint, to WD to hairspray to compressed air to put new grips on. I only use grip glue or spray adhesive anymore. One badly timed landing from a double jump years ago left me 20 feet from the bike with a helmet full of dirt and holding the left grip in my hand. And a temporary limp....
I know I'll never put that kinda strain on a streetbike grip, but once was enough. I glue them on.
Never heard of using gas before, but I never had anything but a plastic throttle tube either......
Posted: Thu Jul 02, 2009 11:35 am
by mydlyfkryzis
If you have a air compressor and a blow gun with needle valve, you can just blow air into the grip, on the end, and the darn thing flies off the handlebar.
