I've been trying to get my head around the difference between single and offset-dual pin cranks. My basic understanding (which may be completely wrong) is that in a single pin, the con rods connect at the same place on the crankshaft, so therefore, the pistons move at the same time. And I guess the reason for having separated firing times is that the pistons have slightlydifferent tdc times, due to the degree of separation (if this is correct, than I assume the firing order will always equal the degree of separation on the cylinders). If all of this is correct, than wouldn't the power created by the first cylinder be wasted initially while the second was still reaching tdc?
Any corrections? Am I even close?
