so ive been fixing up a 1974 yamaha DT125, its a 1 cylinder 2-stroke (although gas and oil are seperate and mixed in the carberator) with 4-stroke oil used in the engine.
in the process i have had to replace the piston with a brand new one and re-bore and fix the cylinder and such
anyway i was curious if there was anything special i should do when firing it up for the first time.
i know when you buy a new bike they say not to exceed "x" amount of RPM's and i didnt know if anything like that applied to my situation
thanks
