Gerbings and a Battery Tender
Posted: Wed Sep 16, 2009 12:16 pm
Hello all! I'm trying to figure out the best way to have both my gerbing heated gear and Battery tender quick connect hooked up to my bike at once. Can I have two harnesses attached to the battery posts at the same time? Is this safe?
My current solution was to attach the Gerbings harness and then use their round plug to SAE adapter. But shortly after buying this adapter I spoke with someone at Gerbing who said this adapter has been discontinued because it was found to be unsafe!
