Suzuki GR650X tachometer problem
Posted: Sat Oct 17, 2009 6:07 am
I bought a 1983 Suzuki GR650X Tempter last month. The bike runs great, but the tachometer has suddenly stopped working. I found that the cable which runs from the engine to the tachometer had come loose, and reattached it, but it had no effect.
The backlight works, and so does the fuel gauge (which is located inside the same section of the dashboard as the tach). But the needle does not move from zero, regardless of how high I rev the engine. I pored over the manual for an hour, and discovered that the problem is exceedingly well documented (NOT).
Any ideas for troubleshooting this?
