1983 Honda GL650
Posted: Sun Dec 13, 2009 4:06 am
I am wondering if anyone can provide me some feedback on questions I have re: this vintage bike. In early October I completed a 4560 mile cross country trip from RI to CA via southern route. At the start of the trip, the tires had about 3100 miles on them. At the end of the trip, the rear tire's tread was worn away completely, i.e. completely flat in the middle. Tread wear was noticeably more aggressive in the hot regions where temps were over 100F as, for the first half of the trip, wear appeared normal and minimal. What seemed odd to me was that tread wear on the rear tire was not symmetrical, i.e. tread depth (remaining) on the left outer edge of the tire was significantly more than what remained on the right edge. I took a photo of it and kept the old tire for reference. This bike has a shaft drive with "PRO LINK" rear suspension in lieu of two shocks. I do not see any adjustment in the rear suspension but am wondering if something may be out of alignment to account for this noticeable disparity in tire wear at the edges.
The other question I have is re: a spongy feeling to the two front discs. Purchased rebuild kit for the master cylinder and bled fom top to bottom and bottom to top, but still get a spongy feeling when depressing lever. What I notice though is that the original rubber hoses can be seen to flex upon applying pressure. I am wondering if I don't have it bled completely of air or if I should replace original OEM hoses with SS braided lines. Bike now has 23K miles on odometer.
