1957 6T "Ramp Cam" Gears
Posted: Wed Dec 30, 2009 10:44 am
by siccatt
[/b]
Greetings,
I have a 1957 Thunderbird 6T. It has the "Ramp Cams". The Cam
gears themselves have not a timing mark 1 on them! The center gear has
all the marks on it as does the crank gear. As the engine came to me already disassembled I have no way of telling what is what. None of the
manuals I have make mention of cam gears with no timing marks. I
know from past experience some industrial engines use the key way
as a starting timing mark. I do not feel this is the case here though.
Can anyone shed some light on this for me??????
Respectfully Submitted,
Siccatt
Posted: Wed Dec 30, 2009 3:16 pm
by Johnj
They do unless their wore off.
!957 6T Cam Gears without timing marks.
Posted: Thu Dec 31, 2009 10:13 am
by siccatt
Thanks for the response. Your pictures are the ones I have also. There
are no pictures of cam ends showing key way location. My gears show no wear. They appear to never had any marks at all. That is why I need a picture of a cam showing an end view, that way I could see the relationship of the key way to the cam gear timing mark. Please this
is driving me up the wall!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks and Happy New Year, Siccatt
Posted: Fri Jan 01, 2010 2:20 pm
by Johnj
If you have this book you must know the cams are in the right position as represented in the picture.
This picture shows when the valves open and close.
!957 6T "Ramp Cams" Gears
Posted: Sat Jan 02, 2010 4:52 am
by siccatt
Wow!!!!!!!! Out of my manuals I do not have that diagram!
Would it be possible for you to show me the manual you are using?
If not too much trouble could you scan in that section if I am unable
to obtain the manual? I have an original "shop" manual for the 5T
6T and T100, as well as an original factory 6T manual, and a Clymer
service manual. I have not seen anything as extensive as what you
are showing.
Thanks so much for your interest in this matter.
Best Regards, Siccatt
