Valve job for '02 GSX-R750 Questions
Posted: Sun Apr 18, 2010 8:01 pm
Hi all,
First off, I'm new around these parts, but from what I've seen so far, this looks like a really helpful and active community and I look forward to participating.
I'm getting my bike ready for the coming riding season and, primarily due to money concerns, I'm going to have to do as much of the maintenance as possible on my own. One item that needs to be done is a valve job since mine are clicking like some kind of giant insect, but I've never even tried to do this on my own. I do have the maintenance manual, and it looks simple enough, but I'm not 100% sure that I'm reading the thing right which has left me with a few questions. First, is this something I can do without having to remove the engine from the frame? Tonight I pulled the airbox to see if there might be enough room to work in there and, while it looks pretty tight, it looks like there is still enough room to get the camshaft cover off, but again, I'm not sure. Second, I'm wondering what I will need to get the job done properly? The manual suggests that all I would need is the valve tool and the shim set and I should be good. That being said, I can afford the valve tool, but I've not been able to find a shim set for less than $70 and even those are not the correct 1.20mm - 2.20mm set described by the manual, but rather about 2mm - 4mm, making most of them too big for my application. Do most dealerships carry individual shims so I can find the ones I need and buy only those? I've even read about people trading in their current shims for the new ones.... is this an option for me? The last question I have relates to the timing chain and/or tensor... Is this something that I check along with the valve clearance? Or is it a fully separate and more involved job? The maintenance manual simply says to check it and see if it moves freely and if not to replace it... it doesn't give any real instructions about how to get to it...
Thanks in advance for all help here,
Greg
PS: Last dumb question that I have to ask every year because I only do it once a year... I have a 6v-12v battery charger / tender which I use to charge up my battery for the coming year. Do I need to run it on the 6v setting or the 12v setting? Or does it matter? Thanks again.
Greg
