1981 suzuki gs550 wiring problem!
- Tricycle Squid
- Real Name: Scott Gray
- Years Riding: 8
- My Motorcycle: 1981 suzuki gs 550
Whoever had it messed it up pretty good, now when I try to start it the main power that goes into the fuse panel is melting the prongs that hold the fuse in place into the plastic. I've went through it 6 or 7 times and still can't find the problem even with the wiring diagram. Any suggestions?
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
Re: 1981 suzuki gs550 wiring problem!
To start check the fuse panel. If any connections are loose or corroded they will heat up.
Then you are down to tracing every wire to find any bare wire or rubbed spots. 30 years of
use / viabration takes a toll on the wiring.
Have fun,
Pete
Have fun,
Pete
