Accelerated Tire Tread Wear, Help!
Posted: Sat Jul 02, 2005 2:30 am
Hello,
I'm the owner of a 1986 Virago 700 shaft driven. I purchased it two summers ago and love riding. Since purchasing, I've added all sort of goodies to the bike. Approximatley 1,500 miles ago, I put brand new Dunlop 404 tires on the bike. The front tire still looks brand new. My problem is the rear tire. It's already in worse shape than the tire I replaced. Tread depth for new Dunlop 404 is 9/32. The tread is slick in the middle 3 inches of the rear tire. My first reasoning for the accelerated tire wear was to much air. I've always kept 36 psi in the tire which is what is recommended. I checked allignment (by wrapping fishing line around rear tire and stretching past front) and it's only 1/8th of an inch off. I don't think 1/8th is enough to cause the tread to wear that fast and I'm not even sure how you would align the motorcycle due to being shaft and not chain/belt. The local yamaha dealership balanced the tires when they replaced with my old ones.
Thanks for reading and would appreciate and advice.
Also, I've used as many as three pressure guages at one time to make sure I was putting 36 psi in the rear tire and the arrow of direction is pointing in the right direction and I ride mostly solo. I've never burned out the tires. I've always been easy on the motorcycle and I'm the only driver.
Is 1,500 miles all that I can expect to get out of a new tire? If not, how many?
