So I jumped my battery after winter, spring, half of summer
Posted: Tue Jul 06, 2010 3:03 pm
Hey!
I was wondering if y'all had any suggestions as to the following problem. I have an 1983 Honda Nighthawk 650, and I'm sure that on a bike so old something can go wrong, but it is in almost flawless condition and barely has 10k miles and worked fine last year.
So I had not used my bike since last fall, and I decided to jump it using my car as the donor battery. The battery was not completely dead. The headlight was very dimly lit and the startup lights were also lit, but of course not enough juice to produce the tiniest of efforts in turning the engine over. I have now learned that some people don't recommend using a car to jump a bike, but I googled it earlier and its at least not fatal, but not ideal method, right?
I connected the cables in the proper order but made the mistake of trying to use the bike battery's negative so there were a few sparks since it is so close to the positive. I quickly moved the negative cable to the bike's frame and everything was fine. My car was always off. I gave it a few tries, but it would not actually start. The headlight was bright, the starter was loud, the horn was loud, etc. After about 5 minutes of trying, with the choke on, it finally started. I quickly disconnected the cables in the proper order, but I noticed they were very hot...enough that I was weary of having to do it again.
The bike then ran like a champ for probably 10-13 minutes. The last 5 of which were with the choke off. I figured it was ready to start on its own so I killed it and when i tried to restart it, it was back to the way i found it. The dim headlight and startup lights, but not enough to even turn the starter over. My immediate guess is that I needed to let it run for way longer, but because of how hot the cables were I figured I would ask people that know better than I do.
So my questions are: Does it sound like there is something else wrong with it? Or, I was right in thinking it just needed to run for longer? If the latter, should I avoid using my car battery as a donor or is it just fine and the cables getting that hot is normal?
THANKS!
THANKS!
