1980 KZ1000 LTD
Posted: Thu Jul 08, 2010 5:33 pm
by JOHNboyDAVIS123
STILL HAVENT FOUND ANY HELP ON HOW TO TIME THIS KZ1000 MOTOR I KNOW WERE TO PUT THE CRANKSHAFT I JUST DONT KNOW ALL ABOUT THE CAMS ITS CLOSE I KNOW BECAUSE IT WILL START BUT IT JUST ANT RIGHT .
1980 KZ1000 LTD
Posted: Thu Jul 08, 2010 5:58 pm
by JOHNboyDAVIS123
DOES ANY BODY KNOW WERE OR WITCH DIRECTION THE CAMS NEED TO POINT OR SHOULD I SAY THE TIMING MARKS NEED TO POINT WHEN PUTTING THIS ENGINE BACK IN TIME.
Re: 1980 KZ 1000
Posted: Thu Jul 08, 2010 6:00 pm
by Wrider
Re: 1980 KZ1000 LTD
Posted: Fri Jul 09, 2010 3:30 am
by Johnj
I suggest that you get a service manual for your bike. The procedure takes about three pages the explain.
Re: 1980 KZ1000 LTD
Posted: Sat Jul 17, 2010 9:14 pm
by JOHNboyDAVIS123
I KEEP TRYING AFTER I POSTED THIS AND IT FINALLY CAME BACK TO ME AFTER A FEW MORE TRYS I GOT THE OLD BIKE GOING IT RUN GREAT BUT THANKS FOR THE HELP . ITS PRETTY SIMPLE PUT CRANK AT TDC THEN PLACE INT CAM SO MARKS ARE INLINE WITH GASKET SURFACE MAKE SURE THE SLACK IS OUT OF CHAIN FROM CRANK TO INT CAM THEN COUNT 28 PINS AT THE 28TH PIN PUT YOUR EX MARK AND THERE YOU HAVE IT PUT ALL YOUR CHAIN IDLERS IN PLACE THEN YOUR TENSIONER IN PLACE AND SPIN THE MOTOR SLOWLY AND CHECK ALL YOUR MARKS THEY SHOULD BE AOK.
Re: 1980 KZ1000 LTD
Posted: Sun Jul 18, 2010 2:11 pm
by ceemes
Good to hear you got it sorted. However, posting in all caps is considered to be shouting and somewhat rude.
