Page 1 of 3
Shaft final drive
Posted: Sun Aug 15, 2010 4:21 am
by Amdonim
I replaced my final drive oil today. I'm not entirely sure but I thought I saw a metal shaving or two stuck to the fill cap. It was covered in oil so it may have been something else I guess. It wasn't a lot, just a spec or two. Is this normal wear and tear? Btw the bike has just at 48000 miles, so this is only the second time the oils been changed as per the manual.
Thanks for your time.
Btw, I love the smell of hypoid gear oil in the morning. It smells like victory.
Re: Shaft final drive
Posted: Sun Aug 15, 2010 7:04 am
by Wrider
A flake or two I wouldn't be worried about. Now if the oil starts to look silvery or if there's more than that it's time to investigate.
But at 48K on a shaftie? Shouldn't be a problem in the world!
Posted: Sun Aug 15, 2010 10:04 am
by Amdonim
Cool. The fluid was the normal blue-ish color. Pretty much the exact same color as the new stuff I put in. Thanks for the help.
P.s while I have your attention, the owner's manual said that the engine oil change interval is 8000 miles. Does that seem abnormally high to anyone else? It recommends GP 40 which I'm pretty sure is conventional. I'm a bit harder on my engine than the average rider so I've been changing it every 2000-3000. I mean I know Honda wrote it, so it should pretty much be a law of physics, but 8000 miles?
Posted: Sun Aug 15, 2010 12:38 pm
by Wrider
Good to hear!
And as for your engine, not really unusual, but make sure it's saying miles not kilometers. Otherwise I'd go with whatever you're comfortable with. 8K should be fine, if you're feeling a bit paranoid, try doing it at 5 or 6K instead.
Posted: Sun Aug 15, 2010 2:08 pm
by HYPERR
Amdonim wrote:Cool. The fluid was the normal blue-ish color. Pretty much the exact same color as the new stuff I put in. Thanks for the help.
How many miles do you ride a year?
Posted: Wed Aug 18, 2010 9:47 am
by Amdonim
Between 15-20k
Posted: Wed Aug 18, 2010 10:11 am
by HYPERR
Amdonim wrote:Between 15-20k
On the newer Honda/Acura cars, the oil change interval is no longer done by mileage or time. They now come with an oil life gauge which calculates oil degradation using various data. The oil life computer usually tell the driver to change the oil at around 5000 miles. So if Honda cars need to have their oil changed at 5K, how can a wet clutched unit construction Honda motorcyle engine go 8000 miles??? Makes no sense.
Yeah I would continue changing it at the 3000 mile interval. You can go longer if you use synthetic.
I would think that an oil with 8000 miles on it , it would be awfully difficult to find neutral on a hot day at a stop.
Posted: Wed Aug 18, 2010 11:24 am
by Amdonim
Ya I agree. Ever since my first bike I've always been paranoid about oil. I double checked it, it says 8000 miles. Oh well. It's not that expensive. If it can handle that, it's $35 for a little peace of mind.
Posted: Wed Aug 18, 2010 1:53 pm
by Wrider
Because it's not a high performance engine, runs a bit cooler than the average car engine, and isn't submitted to as many heating/cooling cycles as most cars are per mileage.
Posted: Wed Aug 18, 2010 2:55 pm
by HYPERR
Wrider wrote:Because it's not a high performance engine, runs a bit cooler than the average car engine, and isn't submitted to as many heating/cooling cycles as most cars are per mileage.
What about the unit construction as well as the wet clutch?
