Page 1 of 2
Wind noise - raising shoulders
Posted: Fri Jul 08, 2005 7:00 am
by biclops
I've just thrown money at a new Shoei RF-1000 and much to my disappointment, the helmet suffers from horribly loud wind noise (on my head, at least).
Above 100km/h, the wind buffets around the base of the helmet at a deafening level. However, shrugging the shoulders cuts it out entirely.
Are there any devices designed to cut down on this type of wind noise? Such as thick neck padding or shoulder baffles (hideous, I'm sure).
I've use the helmet only once for 1 hour and I'm debating putting it up for sale and trying another helmet.
Thanks,
Simon
Posted: Fri Jul 08, 2005 7:29 am
by ronboskz650sr
My Joe Rocket jacket has a rolled collar that extentds into the area under the helmet, and cuts this noise alot. Do you wear earplugs? I found a pair of washable silcone based soft plugs...the kind with circle baffles getting larger as they go down the plug. They were at Walmart, and come with a cord to keep them together if you swim with them. I cut the cord, and have used them for almost 6 months. They are very comfortable, and very quiet, but you can still hear all the important stuff. All without the wind noise.
Posted: Fri Jul 08, 2005 7:38 am
by biclops
ronboskz650sr wrote:Do you wear earplugs? I found a pair of washable silcone based soft plugs...
Thanks Ron,
Yeah, I always wear slow-rebound foam ones. The jacket I have has no real collar. I will try to demo a jacket with a big collar.
Posted: Fri Jul 08, 2005 7:51 am
by ronboskz650sr
Posted: Sat Jul 09, 2005 6:16 am
by DustyJacket
They also have a windscreen that snaps across the chin area of your helmet. Kind of a 1/4 moon shape, horizontally.
Posted: Sat Jul 09, 2005 12:56 pm
by Renegade
DustyJacket wrote:They also have a windscreen that snaps across the chin area of your helmet. Kind of a 1/4 moon shape, horizontally.
What he said...
That helps a TON! They come with the X11 helmets and just snap in. HUGE difference.
A lot of the wind noise simply depends on where the bubble is. If you have a shield of any kind there are different things you can do as well. There are different edging treatments to can add to the shield as well that will bust up the flow a bit.
Start with the under the chin net though.
Posted: Sun Jul 10, 2005 8:48 pm
by biclops
Thanks, I've tried this since and it sounds much better. It came with the helmet, but I wrongly assumed it was simply a cold weather thing. I will continue to try minimizing the buffeting.
Posted: Wed Jul 20, 2005 12:15 am
by HypeDOG
Wouldn't it be nice if dealers has an air tunnel or some type of booth where you could put the lid on your head and they would through 100km'h air at your face?
Posted: Wed Jul 20, 2005 9:59 am
by Keyoke
HypeDOG wrote:Wouldn't it be nice if dealers has an air tunnel or some type of booth where you could put the lid on your head and they would through 100km'h air at your face?
You could try putting on the helmet, ad running around the showroom really quickly??
Posted: Wed Jul 20, 2005 11:01 am
by HypeDOG
If only I get enough momentum
