heat problems
coolbone28
heat problems
#1 Unread post by coolbone28 »
Hello all. I have a '99 Suzuki Intruder 1400 and it just recently started to get really hot...almost to the point where it is burning my legs. are there any ideas as to why this jsut started happening? i have had the bike for a couple years. I've taken it to shops and had them dyno it. the oil is fine and i just cleaned out the carb and adjusted it. but still no luck. and it happens all the time...does not matter if i am pulling a grade or flying off a cliff. thanks for the help.
#2 Unread post by BuzZz »
Shooting in the dark.......
Have you added any airflow changeing/blocking accessories to the bike lately? Windshields, chrome headlight or fork shrouds, front fender, ect?
Gadjet
Real Name: Owen Clark
Years Riding: 19
#3 Unread post by Gadjet »
How's your coolant level? If you are getting low on coolant, then engine temp is going to increase.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
coolbone28
#4 Unread post by coolbone28 »
thanks for the replies. it happened without any mods. added to the bike and as far as i know it is air/oil cooled. does not have coolant. if anyone has a heat gun can you give me the avg. running temp on your bikes? thanks again.
Gadjet
Years Riding: 19
#5 Unread post by Gadjet »
you're right, it is air/oil cooled. I thought it might be liquid cooled, as the '97 model is liquid cooled. My mistake.
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
TechTMW
#6 Unread post by TechTMW »
Ugh. blocked oil passages maybe?
Or, your bike might be running really lean. A really lean bike will run like snot, until the pistons gall and sieze. You may need to recheck your carbies and se tthem to the stock settings. The bike doesn't ahve any Intake/exhaust mods?
kar_the_terrible
#7 Unread post by kar_the_terrible »
On a related note. What is too hot for an air-cooled engine? Is it normally specified in the shop manuals?? Or is there a more indirect way of telling if a bike is running too lean/rich like maybe dyno or EGA...
'78 Yamaha XS400
'86 Yamaha Radian
