2011 H-D V-Rod Muscle- COOL WALL VOTE: COOL
Posted: Fri Feb 11, 2011 2:15 am
2011 Harley-Davidson VRSCF V-Rod Muscle
http://www.totalmotorcycle.com/photos/2 ... Muscle.htm
The fast, powerful and aggressive V-Rod Muscle™ motorcycle is built for riders who want a little extra beef with their horsepower. Big meaty air scoops, muscle-bound mufflers, 240 mm rear tire, fastback-style tail section and massive airbox compliment the power of the 1250 cc liquid-cooled Revolution engine. Ride the V-Rod Muscle™ and experience the true definition of "power cruiser." This brawny beast is for performance enthusiasts who crave power and control, with a dash of intimidation, in a package that is all Harley-Davidson.
DIMENSIONS
Length 92.8 in. (2357 mm)
Overall Width 40.2 in. (1021 mm)
Overall Height 45.7 in. (1161 mm)
Seat Height:
• Laden2 25.6 in. (650 mm)
• Unladen 26.7 in. (678 mm)
Ground Clearance 4.8 in. (122 mm)
Rake (steering head) 34°
Fork Angle 34°
Trail 5.6 in. (142 mm)
Wheelbase 67.0 in. (1702 mm)
Tires (Michelin® Scorcher™ “11” front and rear):
• Front – Scorcher™ “11” 120/70ZR-19 60W
• Rear – Scorcher™ “11” 240/40R-18 79V
Fuel Capacity 5.0 gal. (18.9 L) (warning light at approximately 0.5 gal.)
Oil Capacity (w/filter) 5.0 qts. (4.7 L)
Coolant Capacity 2.5 qts. (2.4 L)
Weight:
• As Shipped 640 lbs. (290.0 kg)
• In Running Order 673 lbs. (305.0 kg)
• Gross Vehicle Weight Rating 1075 lbs. (488.0 kg)
• Gross Axle Weight Rating
• Front 377 lbs. (171.0 kg)
• Rear 698 lbs. (317.0 kg)
ENGINE
Engine3 Liquid-cooled, Revolution®, 60° V-Twin
Valves Overhead cam, 4 valves per cylinder, solid tappet with shim-under-bucket lash adjustment
Bore x Stroke 4.134 in. x 2.835 in. (105 mm x 72 mm)
Displacement 76.28 cu. in. (1250 cc)
Compression Ratio 11.5:1
Fuel System3 Electronic Sequential Port Fuel Injection (ESPFI)
Air Cleaner Down draft intake
Lubrication System Wet-sump, integrated with powertrain crankcase
DRIVETRAIN
Primary Drive Gear, 117/64 ratio
Final Drive Belt, 72/28 ratio
Clutch 9-plate, wet, A&S (Assist & Slip)
Transmission 5-speed
U.S. Gear Ratios (overall):
• 1st 11.752
• 2nd 7.898
• 3rd 6.322
• 4th 5.459
• 5th 4.899
CHASSIS
Frame Steel perimeter upper frame with hydroformed main rails and bolt-on lower frame rails; MIG welded
Swingarm Polished, one-piece cast aluminum Front Forks 43 mm Inverted
Rear Shocks Preload adjustable
Wheels4: Black, 5-Spoke Cast Aluminum
• Front 19 in. x 3 in. (483 mm x 76 mm)
• Rear 18 in. x 8 in. (457 mm x 203 mm)
Brakes:
• Caliper Type 4-piston front and rear
• Rotor Type (diameter x width): Patented, one-piece floating rotor (front), uniform expansion rotor (rear)
• Front (dual) 11.81 in. x .2 in. (300 mm x 5 mm)
• Rear 11.81 in. x .28 in. (300 mm x 7 mm)
• Anti-lock Braking System (option) Available
Suspension Travel:
• Front Wheel 4 in. (102 mm)
• Rear Wheel 2.9 in. (74 mm)
PERFORMANCE
Engine Torque5 (per SAE J1349):
• North America 86 ft. lbs. @ 6500 RPM (117 Nm @ 6500 RPM)
Lean Angle (per SAE J1168):
• Right 32°
• Left 32°
Fuel Economy6
(EPA urban/highway test)
34/42 mpg (6.92/5.60 L/100 km)
ELECTRIC
Battery (per Battery Council International Rating)
Sealed, maintenance-free, 12V, 19-amp/hour, 270 cca
Charging Three-phase, 38-amp system (439W @ 13V, 2000 RPM, 489W max power @ 13V)
Starting 0.08 kW electric with direct drive starter motor engagement
Lights (as per country regulation):
• Headlamp (quartz halogen) 55-watt low beam, 65-watt high beam
• Rear Tail/Stop/Turn Signal Lights Integrated Dual Color LED
• Front Turn Signal Lights Integrated LED
• Indicator Lamps - High beam, neutral, low oil pressure, turn signals, engine diagnostics, security system7 (optional), coolant temperature, low fuel warnings
COLOR OPTIONS
Vivid Black
Brilliant Silver Pearl
Chrome Yellow
White Hot Denim
WARRANTY
Warranty8 24 months (unlimited mileage)
Service Interval First 1,000 miles (1,600 km), every 5,000 miles (8,000 km) thereafter
