i need someones help
Hi guys,
I have had my bike for about a month (new to motorbikes) and just recently as ive been getting up to about 50 km/h its been strugling, jumping, backfiring whatever it is you probably get at what im talking about if not ill explain more. Have you got any idea of what it could be due to? any help i'd really appreciate it, ive just started so i dont know much. thanks all
- Wizzard
- Legendary 1000
And if it has had any modifications done to it .
Regards, Wizzard
Regards, Wizzard
hey thanks for the replys. Its red and black. some japanese brand, pretty close to a honda 100cc ive been told. When i get to a certain speed, and its around about the same speed each time, the reves jump and it gives off little backfires. at first i just thought the bike was cold so walmed it up a bit more, changed the oil...etc. hasnt helped.
from what little we know about this mystery bike it sounds like maybe the main jet in the carburetor is clogged up--take the air cleaner off and close up half of the carburetor intake throat with duct tape and run it if it gets better you aint getting enough fuel through the main jet--if it runs worse you are getting too much fuel through the main jet.i am assuming that it is running bad in the mid or wide open throttle position.
dr bob
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Sounds as close as anything at this piont. Could have caught a chunk of crud let over from manufacture in a jet or something.9000white wrote:from what little we know about this mystery bike it sounds like maybe the main jet in the carburetor is clogged up--take the air cleaner off and close up half of the carburetor intake throat with duct tape and run it if it gets better you aint getting enough fuel through the main jet--if it runs worse you are getting too much fuel through the main jet.i am assuming that it is running bad in the mid or wide open throttle position.
No Witnesses....
