2011 Can-Am Spyder RS-S - COOL WALL VOTE: FAIL
Posted: Sat Apr 09, 2011 1:27 am
http://www.totalmotorcycle.com/photos/2 ... derRSS.htm
There's nothing ordinary about the way it looks. Or the way it rides, for that matter. With its Rotax® 990 V-Twin engine, its advanced Vehicle Stability System (VSS) and unique, three-wheeled stance, the 2011 Can-Am Spyder RS-S roadster offers a bold, new way to experience open-road freedom.
2011 Can-Am Spyder RS Features
New for 2011:
New coloration: Pure Magnesium Metallic and Pearl White with color-matched side panels.
Improved anti-vibration system reduces overall chassis feedback for a better riding experience.
New Spyder RS-S distinctive styling package, offering exclusive two-tone coloration, painted front spoiler and A-arm covers, carbon-black aluminum parts, double 6-spoke black front wheels and stitched seat skin.
The Spyder RS-S package offers all the standard Spyder RS features, PLUS:
Black 6 double-spoke front wheels
• Two-tone coloration
• Painted front spoiler and A-arm covers
• Carbon-black aluminum parts
• RS-S graphics
• Stitched seat
• Transmissions available: SM5 – 5-speed manual with reverse OR
SE5 – 5-speed semi-automatic with reverse
Colors Available: Pure Magnesium Metallic /Steel Black Metallic, Alloy Orange Metallic /Matte Black
2011 Can-Am Spyder RS-S - Specifications
MSRP: TBA. See your local Can-Am dealer.
Engine
Manufacturer BRP-Rotax®
Type 998cc, V-twin, liquid-cooled, DOHC 4
Bore & Stroke 3.82 in. x 2.68 in. (97 mm x 68 mm)
Injection Multi-point EFI system with 2.24 in. (57 mm) throttle body
Power 106 hp (79 kW @ 8500 RPM)
Torque 77 lb.-ft. (104.3 Nm @ 6250 RPM)
Transmissions 5-speed manual (SM5) with reverse OR
5-speed semi-automatic (SE5) with reverse
Magneto 500 watts
Starter Electric
Battery 12 volts / 21 amps/hour, sealed maintenance-free
CHASSIS
Frame SST Spyder
Front suspension Double A-arm with anti-roll bar
Front suspension travel 5.69 in. (145 mm)
Rear suspension Swing-arm with monoshock
Rear suspension travel 5.71 in. (145 mm)
Brake type Foot-actuated, fully integrated hydraulic 3-wheel braking system
Front Brake 4-piston calipers with (250 mm x 6 mm) discs
Rear Brake Single-piston sliding pins caliper with (250 mm x 6 mm) disc
EBD Electronic Brake Distribution
ABS Anti-lock Braking System
Parking brake Foot-operated; engages rear caliper
Front Tires 165 / 65 R14
Rear Tire 225 / 50 R15
Front wheel 3 spokes, aluminum, 14 x 5 in. (355 mm x 127 mm)
Rear wheel Aluminum 15 x 7 in. (381 mm x 178 mm)
SAFETY & SECURITY
VSS Vehicle Stability System
SCS Stability Control System
TCS Traction Control System
DPS Dynamic Power Steering
DIMENSIONS
L x W x H 105 x 59.3 x 45.1 in. (2,667 x 1,506 x 1,145 mm)
Wheel base 68 in. (1,727 mm)
Seat height 29 in. (737 mm)
Ground clearance 4.5 in. (115 mm)
Dry weight 699 lb. (317 kg)
Front storage capacity 11.6 US gal. (44 l)
Front load capacity 35 lb. (15.9 kg)
Maximum vehicle load 440 lb. (200 kg)
Fuel capacity 6.6 US gal. (25 l)
FEATURES
Instrumentation Multi-function LCD/analog gauge: digital speedometer, tachometer,
odometer, trip & hour meters, gear position, temperature,
engine lights, electronic fuel gauge, clock
Anti-theft system D.E.S.S. (Digitally Encoded Security System)
Lighting 2 halogen headlamps (60W) with tail light/brake light
Windshield 10 in. (250 mm) sport
Warranty 2 years
Transmissions available: SM5 – 5-speed manual with reverse (not available with Pearl White) OR
Colors available: Pure Magnesium Metallic/Steel Black Metallic, Alloy Orange Metallic/Matte Black
