2011 Roehr eSuperBike RR (electric) - COOL WALL VOTE: COOL
Posted: Thu Jun 23, 2011 9:54 pm
http://www.totalmotorcycle.com/photos/2 ... BikeRR.htm
The ROEHR eSuperBikeRR
Roehr Motorcycles would like to congratulate all who have participated in this year’s ground breaking 2010 TTXGP and FIM e-Power racing series.
These machines represent a wide range of innovative configurations, solutions, and technologies, showcasing the ingenuity and true spirit of competition of all the teams involved.
Roehr Motorcycles is committed to the continued growth of the sport, as well as increasing the performance capabilities of the electric motorcycle.
We are now offering a high performance, turn-key electric racer to teams and individuals planning to compete in these series.
Whether you are an existing team looking to take the next step to increased levels of performance, or a new team planning to enter this exciting new race series with a competitive platform, the new Roehr eSuperBikeRR offers class leading performance in a cost effective and reliable machine.
The Roehr eSuperBikeRR offers an extremely high level of performance, previously unavailable in a turn-key solution. It is designed and developed to incorporate the finest commercially available, proven components and technologies, resulting in the most cost effective and reliable package possible.
A new American Classic
The dream of owning an American made sport bike that could hold it's own against the world's finest machines has been a dream for many. This dream is now a reality. Not only is the Roehr eSuperBike RR the fastest and most powerful American production sport bike, but one of the top performing machines in the world.
The eSuperBike RR represents the birth of a new American motorcycle brand. A brand committed to producing beautiful, high performance machines made in the USA. The "can do" spirit that made America great is alive and well at Roehr Motorcycles. This passion is the foundation of our brand and expressed through our products.
The Roehr eSuperBike RR, the rebirth of American world class performance.
The excitement is electric
The eRoehr electric motorcycle model lineup consists of three motorcycles, each one uniquely equipped and priced to appeal to a wide range of customer budgets and desires. Each model shares at its core the Roehr Brand DNA of performance, style, and quality.
2011 Roehr eSuperBike RR Features
With 96HP and 210 lb/ft of torque as well as 10Kwh of high discharge LiFeP04 battery technology, the eSuperBikeRR is capable of 135MPH+ top speeds with acceleration to match, providing the speed and range necessary for your team to be battling for the win.
Roehr Bi-Metal Frame Technology
The eRoehr Series feature a unique Bi-Metal beam frame. The frame is constructed of 4130 Chrome-Moly steel and 6061 T6 Aluminum. This method allows each material to be used in areas of the frame that their material characteristics are best suited.
A motorcycle frame needs to be strong, stiff and light weight, but also needs to flex just enough under certain conditions. This controlled flex provides essential information, providing the rider with added confidence near the limits of tire grip. Additionally, this flex also adds a level of dampening which is especially beneficial when the motorcycle is leaned over on the edges of the tires. Under these conditions the motorcycle's suspension effectiveness is dramatically reduced due to road forces no longer acting on the suspension at parallel angles.
The Roehr Bi-metal frame provides a level of dampening that allows the tire to better follow road irregularities under these conditions.
Through the use of computer assisted finite element analysis, the Bi-metal frame was designed using large section, thin wall, 4130 steel, main chassis beams to provide a stiff yet soft structure that is bonded and bolted to extremely strong, stiff yet light weight billet aluminum swing arm pivot plates.
By combining these materials into one structure, the Roehr Bi-Metal frame provides the ultimate combination of strength, stiffness, controlled flex and light weight. This unique frame technology is a major contributor to the stellar handling characteristics of the eRoehr series.
2011 Roehr eSuperBike RR - International Specifications
MSRP - Starting from $35,495 USD
Drivetrain:
Twin Fan Cooled AC Induction Motors
96HP, 210 lb/ft torque
Single speed direct drive
Ratio 12:54
Batteries:
Large format, cylindrical LiFePo4
Capacity: 9.6 Kwh
96 Volts/ 96Ah
960 amps (continuous)
1450 amps (max)
Battery Management System:
LVC, HVC, Shunt balancing
Chassis:
Steel twin spar beam frame with integral
motor and battery mounting substructure.
Rake: 24deg
Trail: 89mm
Wheelbase: 56in.
Suspension:
Front:
43 mm Ohlins inverted
Rear:
Ohlins Single shock with linkage
Brakes:
2 x 320mm Brembo discs
2 x 4 Brambo radial mount
Tires:
120/70/17 front
170/60/17 rear
Overall weight:
500 lbs.
MSRP:
Orders will be filled on a first-come, first-serve basis, requiring a 50% deposit. These machines are built to order, with all required racing equipment installed.
Roehr Motorcycles LLC offers alternate motor and battery configurations specifically suited to your needs.
