i bought this bike at a junk yard and have got it running well but the turn signals do not work. when i turn the switch both indicators on the dash light up but not the signals. i bought a new flasher and the indicators on the dash flash all the time like a warning signal on a car. can't see anything wrong with the wiring.
this is on an 1982 kawasaki kz 1000 csr
turn signal problem on kawasaki
- Real Name: don
- Years Riding: 38
- My Motorcycle: 1982 kawasaki kz 100 csr m
- project k.jpg (58.42 KiB) Viewed 3305 times
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
Re: turn signal problem on kawasaki
If the wiring is realllllly good then the switch is suspect. How difficult is it to remove and clean?
- Johnj
- Real Name: Johnny Strabler
Ok, you installed a new flasher, and is it both indicators flashing all the time now, right?
- Real Name: don
- Years Riding: 38
the wiring is good and the switch is good. i looked at the book and it said that if any one light in the system is bad then the whole system will not work properly so i am going to systematically replace the lights until i see if that is the problem. thanks for your help
