master cylinder 82 kaw
- Real Name: don
- Years Riding: 38
- My Motorcycle: 1982 kawasaki kz 100 csr m
i bought this bike at a junk yard and am working on resoring it. i cleaned the front master cylinder and the calipers and all of the parts looked good, but i ended up buying a master cylinder rebuild kit anyway because i can't get it to work. it just does not seem to want to build up pressure. i have filled the lines with fluid and i have not leaks. any ideas?
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
Re: master cylinder 82 kaw
Likely a bad bore in the MC with pitting or scratches. Otherwise bad hoses flexing instead of holding pressure.
- Johnj
- Real Name: Johnny Strabler
Hello and welcome to the forum.
Does this mean you disassembled and examined the master cylinder and both calipers. You might want to try vacuum bleeding. They sell a kit at the discount tool place.dlmsmay wrote:i cleaned the front master cylinder and the calipers and all of the parts looked good, but i ended up buying a master cylinder rebuild kit anyway because i can't get it to work.
