Page 1 of 2
Question about brakes
Posted: Fri Sep 23, 2011 5:41 am
by xRider
Why isn't the back brake connected to the brake light on my bike? Only the front brake activates the brake light.
I almost only use the back brake because I find using the front brake uncomfortable.
Re: Question about brakes
Posted: Fri Sep 23, 2011 6:38 am
by dr_bar
First off, practice braking with both brakes as the majority of your braking power comes from the front brake.
There should be a switch attached to the rear brake linkage somewhere, and it may be out of adjustment, broken or need a spring to connect it to the linkage. Go looking and I'm sure you'll find it. Theoretically, an easy fix and I'm sure if I'm mistaken or there's another possibility, Wrider or his fellow compadres will chime in...
Posted: Fri Sep 23, 2011 9:34 am
by Wrider
dr_bar wrote:First off, practice braking with both brakes as the majority of your braking power comes from the front brake.
That's exactly what I was thinking.
Usually there's a spring attached to the rear brake lever that pulls on a switch mounted behind your footpeg, and that can come off or break.
And definitely practice with your front brake. My sister was using her rear almost exclusively, and when I finally broke her of the habit she was shocked at how much more braking power she had.
Posted: Sat Sep 24, 2011 6:27 am
by xRider
Thanks, I checked and saw that the spring was only connected to the brake cable and not to the back brake. So I just connected it and adjusted it and now its working fine.
Posted: Sun Sep 25, 2011 6:18 am
by BRUMBEAR
Keep using the back brake to much, make reservations at the hospital there is a reason the front brake radios is more than triple the size of the rear
Posted: Sun Sep 25, 2011 6:33 am
by Wrider
BRUMBEAR wrote: there is a reason the front brake radius is more than triple the size of the rear
Yup, when you brake, the weight of the motorcycle transfers to the front wheel, giving it a whole lot more grip.
Posted: Mon Sep 26, 2011 3:39 am
by Grey Thumper
Wrider wrote:BRUMBEAR wrote: there is a reason the front brake radius is more than triple the size of the rear
And of course, the same weight transfer means less weight on the rear wheel, and a corresponding decrease in grip. A loss of enough traction makes it more likely that the rear wheel will lock, which basically means the doo doo will soon fly into the oscillating wind-making device.
Posted: Mon Sep 26, 2011 8:22 am
by storysunfolding
BRUMBEAR wrote:Keep using the back brake to much, make reservations at the hospital
Which primary control can you use too much without needing the hospital?
Posted: Mon Sep 26, 2011 2:00 pm
by BRUMBEAR
Throttle Baby if don't work you were going to the hospital anyway when in doubt GAS IT OUT!!!!!! Just kiddin I wanted to make as strong a point as possible that rear brake as a primary is BAD MEDICINE
Posted: Mon Sep 26, 2011 3:46 pm
by storysunfolding
Interesting that you picked a track saying convincing someone to stay on the throttle and off the brakes.
Of course, no one has ever used too much throttle
http://www.youtube.com/watch?v=QKsOGFh3Efk
The rear brake remains an important control on a motorcycle. Gives more stopping power for street riding, and you need it to be competitive for track riding. When a rider realizes that they can't use it appropriately, it's time for the rear brake to become their focus in learning.
