2012 Suzuki TU250X - VOTED: COOL
Posted: Thu Oct 27, 2011 9:35 pm
2012 Suzuki TU250X
http://www.totalmotorcycle.com/motorcyc ... TU250X.htm
Tradition comes alive in the Suzuki TU250X. With its classic styling, including spoked wheels, a round headlight and sweptback muffler - and plenty of chrome - it's designed to remind everyone that motorcycling is all about fun. That all begins with light, agile handling complemented by smooth performance. Best of all, it's designed to combine the fun of riding with truly economical performance.
Get a grip on a whole new standard. Striking looks. Comfort. Power. Versatility. Our standards deliver easy ergonomics, modern style, and metro muscle in dynamite packages. Whatever type of riding you prefer, our standards can handle it.
2012 Suzuki TU250X Key Features
Contemporary styling thanks to chrome-plated front and rear wheels, headlight case, speedometer cover, tail lamp housing, front suspension outer tube and polished crank side case produce a beautiful, high quality look.
Low 30.3 inch seat height and compact chassis provide confidence-inspiring performance for beginning riders.
2012 Suzuki TU250X Features and Benefits
Engine Features
249cc, air-cooled four-stroke, single-cylinder, SOHC engine with Suzuki's industry leading fuel injection system is tuned for strong low-end torque well-suited for city riding.
Suzuki Composite Electrochemical Material (SCEM) Plated cylinder for improved durability, weight reduction and superior heat transfer.
Effective engine management and emissions control systems working together with Suzuki Dual Throttle Valve (SDTV) fuel injection system, featuring 32mm throttle body, provides superb throttle response, smooth power delivery and reduced emissions.
Digital ignition provides optimum ignition timing for increased efficiency and crisp throttle response.
PAIR (Pulsed-AIR) system injects fresh air into the exhaust port to ignite unburned hydrocarbons, further reducing emissions.
Transmission Features
Smooth-shifting 5-speed transmission has gear ratios suitable for a wide variety of riding conditions.
Chassis Features
Diamond-shaped steel tube frame is lightweight and strong, producing confident and agile handling.
Exhaust system is outfitted with a catalytic converter and oxygen sensor feedback system reducing exhaust emission.
3.2-gallon fuel tank and fuel-efficient engine provide excellent riding range.
Full lighting system and easy-to-read instrumentation includes a trip meter.
Front disc brake with dual-piston caliper and rear drum brakes offer strong braking capabilities.
2012 Suzuki TU250X - USA Specifications/Technical Details
US MSRP Price: $4099 USD <- UPDATED PRICE
Chassis
Overall Length 2070 mm (81.5 in)
Overall Width 750 mm (29.5 in)
Wheelbase 1375 mm (54.1 in)
Ground Clearance 165 mm (6.5 in)
Seat Height 770 mm (30.3 in)
Curb Weight 148 kg (326 lbs)
Transmission 5-speed constant mesh
Final Drive Chain, DID520V, 108 links
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Swingarm type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Drum brake
Tires Front 90/90-18 M/C 51S, tube type
Tires Rear 110/90-18 M/C 61S, tube type
Fuel Tank Capacity 12.0 L (3.2 US gallons)
Engine
Displacement 249cc, 4-stroke, air-cooled, single cylinder, OHC
Fuel System Suzuki fuel injection
Starter Electric
Ignition Electronic ignition (transistorized)
MPG 79
Warranty
Warranty 12 month unlimited mileage limited warranty.
Engine Features
Chassis Features
Chassis
Engine
Starter Electric
MPG 79
Warranty
