Front Brake Reservoir Leak.
Posted: Sat Jul 23, 2005 10:05 am
Okay for the last day or two the reservoir next to my front brake lever has been leaking fluid. I saw it and noticed that it was not very tight, so I gave it a turn or two. Wiped it clean and came out a bit later to find that near the top where the seal connects to the reservoir, there is a substance 360 degrees around the seal. Wiped it clean and went to bed. Woke up this morning and went out to check it and much to my dismay there was more substance 360 degrees around the seal. So today I called Ducati and the mechanic said that he would not be able to look at it until the first of
August. Or I could have the owner check it out Monday or Tuesday.
Shortly after that my neighbor came down and I told him what was going on. Turns out he was really big into motorcross. So I showed him the problem and he came up with 2 things.
1. The seal isn't sealing up completely.
2. It is very hot outside. (98 degrees outside and the bike is in a garage mind you. So that ups the temp a bit.) The heat is evaporating the fluid and the seal is not keeping the fluid in. Hence the substance around the seal.
We checked my dads bike and his brake fluid tank was dry and fluid free around the seal.
In conclusion me and my neighbor are almost sure that the seal is bad. If the seal was functional, the heat should not cause the fluid to come out around the seal.
Give me your .02 on this.
