broken pilot jet
Posted: Thu Jan 12, 2012 8:22 am
by skikman
i got an old yamaha sr250 going but it was backfiring through the exhaust when i let the throttle off.i took off the carb to have a look and noticed the pilot jet head is wrecked or broke off inside the tube[if you know what i mean]. i cant get it out.anyone know a trick of how i could get it out without breaking the tube.
Re: broken pilot jet
Posted: Thu Jan 12, 2012 5:35 pm
by Wrider
Can you take a picture of what you mean?
Posted: Thu Jan 12, 2012 10:30 pm
by skikman
Posted: Fri Jan 13, 2012 3:44 am
by Wrider
Hmmm, that is buggered up pretty good. You could try a small reverse (left hand twist) drill bit. It should bite into the brass pretty easily and twist it out.
Posted: Fri Jan 13, 2012 7:57 am
by skikman
Wrider wrote:Hmmm, that is buggered up pretty good. You could try a small reverse (left hand twist) drill bit. It should bite into the brass pretty easily and twist it out.
can you get them that small?
Posted: Fri Jan 13, 2012 9:46 pm
by Wrider
Oh yeah, something along the lines of a 1/8th or 1/16th ought to work just fine. It'll drill into the brass a little, make sure it gets a good bite, and quick jerks should pull out your jet.
