2013 Victory Judge - VOTED: Awesome
Posted: Thu Jan 19, 2012 11:05 pm
2013 Victory Judge
http://www.totalmotorcycle.com/motorcyc ... -Judge.htm
2013 Victory Judge
American muscle never died. It just needed handlebars.
Available in dealerships April 2012
2013 Victory Judge Model Highlights
•106 cubic-inch Freedom V-Twin Engine
•113 ft lbs torque
•Mid mounted controls
2013 Victory Judge Features and Benefits
A NEW CRUISER EXPERIENCE
Victory reinvented the cruiser riding experience with the premium ride and performance of the Vegas. Now Victory again introduces a high new level of cruiser excitement with the stylish, sport-influenced Victory Judge.
MID MOUNTED CONTROLS
The mid mounted controls put the driver in an active, engaged riding position. The rider is confidently in total command of the bike, and the ergonomics ensure long-riding leg comfort for riders on the open road.
ALL-NEW VICTORY STYLING
Only Victory offers such distinctive cruiser styling. The Victory Judge is a powerful rolling sculpture showcasing fresh bodywork, blacked-out features, new drag handlebars, a new headlight nacelle and side panels an owner can customize. The Victory ignition cover between the cylinders also features a great new look.
AMERICAN CRUISER STYLE
The Victory Judge combines modern high-performance technology with American styling cues of the 1960s muscle car era, such as cast 5-spoke wheels. The 16" wheels are shod with premium Dunlop Elite II tires with raised white lettering, the perfect look on this cruiser.
CONFIDENCE-INSPIRING RIDE & HANDLING
Beautifully balanced and engineered with a low center of gravity, the Victory Judge is a full-sized cruiser with sporty & performance-oriented handling that instills confidence and delivers an incredibly smooth ride.
106 CUBIC-INCH FREEDOM V-TWIN
The pulse of the street beats from within the powerful Freedom® 106/6 V-Twin. Its serves up 113 ft-lbs of torque that lets a rider accelerate through the gnarliest traffic and bask in the freedom of the open road.
6-SPEED OVERDRIVE TRANSMISSION
Helical-cut gears in the durable, reliable 6-speed transmission deliver consistently smooth shifting. The true overdrive of 6th gear provides a rider with the smoothest highway cruising.
113 FT-LBS OF TORQUE
The Freedom® 106/6 V-Twin delivers instant throttle response and outstanding acceleration that gets a rider off the line and through traffic in complete control. Even while cruising in 6th gear, there's passing power to spare
2013 Victory Judge - USA Specifications/Technical Details
USA MSRP Price: $13,999 USD
Canada MSRP Price: $15,299 CDN
Engine
Battery 12 volts / 18 amp hours
Bore x Stroke 101 x 108 mm
Charging System 38 amps max output
Clutch Wet, multi-plate
Compression Ratio 9.4 : 1
Cooling System Air / oil
Displacement 106 ci / 1731 cc
Engine Type 4-stroke 50° V-Twin
Exhaust Staggered slash-cut dual exhaust with crossover
Final Drive Carbon Fiber Reinforced Belt
Fuel Capacity 4.5 gal / 17.0 ltr
Oil Capacity 5.0 qts / 4.75 ltr
Primary Drive Gear drive with torque compensator
Transmission 6-speed overdrive constant mesh
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Chassis
Dry Weight 660 lbs / 300 kg
Ground Clearance 4.7 in / 120 mm
GVWR 1151 lbs / 522 kg
Length 92.0 in / 2337 mm
Rake/Trail 31.7o / 6.7 in / 170 mm
Seat Height 25.9 in / 658 mm
Wheelbase 64.8 in / 1647 mm
Suspension
Front Suspension Conventional telescopic fork, 43 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube gas, cast aluminum with rising rate linkage, 3.0 in / 75 mm travel, preload adjustable spring
Brakes
Brake System Type Conventional
Front Braking System 300mm floating rotor with 4-piston caliper
Rear Braking System 300mm floating rotor with 2-piston caliper
Wheels & Tires
Front Tire 130/90 B16 67H Dunlop 491 Elite II-RWL
Front Wheel 16 x 3.5 in
Rear Tire 140/90 B16 77H Dunlop 491 Elite II-RWL
Rear Wheel 16 x 3.5 in
Color
Colors Gloss Black; Sunset Red; Suede Nuclear Sunset
2013 Victory Judge
•113 ft lbs torque
Engine
Chassis
Suspension
Brakes
Wheels & Tires
Color
