2012 Kawasaki Ninja ZX-10R ABS: Voted: Awesome
Posted: Fri May 04, 2012 7:36 am
More photos and information: http://www.totalmotorcycle.com/motorcyc ... 10RABS.htm
Passion and Speed Meet Advanced Technology
The highly advanced 2012 Ninja® ZX™-10R has just met its match: The 2012 Ninja ZX-10R ABS. Built with the same cutting-edge sport bike technology, much of it right off the MotoGP circuit, the ZX-10R ABS has an important advantage: anti-lock braking.
At first, anti-lock braking might seem a touch out of place on a purebred sportbike. But this system was designed from the start to provide maximum performance. And when you consider the many safety- and control-oriented benefits provided by the amazing electronic and hardware technology available today, it begins to make a lot of sense.
Think of it: You’re braking for a blind, decreasing-radius corner after a long day of sport riding. Shadows are long and you’re tired, so you don’t notice a patch of sand until it’s too late to correct. But instead of tucking as you continue braking through the sand, your front tire maintains most of its traction, as the anti-lock braking system intervenes until the surface improves – allowing you to arc gracefully into the corner, a little wiser and a lot more intact physically than you might have been riding a non-ABS motorcycle.
Kawasaki calls its anti-lock system KIBS – or Kawasaki Intelligent anti-lock Brake System. The use of “intelligent” is apropos, too, considering just how smart the new KIBS is. It all starts with the smallest and lightest ABS unit ever built for a motorcycle, one Bosch designed specifically with sport bikes in mind. It’s nearly 50 percent smaller than current motorcycle ABS units, and 800 grams lighter, adding only about 7 pounds of weight compared to the non-ABS machine, a pound of which is accounted for by the larger battery.
KIBS is a multi-sensing system, one that collects and monitors a wide range of information taken from wheel sensors (the same ones collecting data on the standard ZX-10R for its S-KTRC traction control system) and the bike’s ECU, including wheel speed, caliper pressure, engine rpm, throttle position, clutch actuation and gear position. The KIBS’s ECU actually communicates with the bike’s engine ECU and crunches the numbers, and when it notes a potential lock-up situation, it tells the Bosch ABS unit to temporarily reduce line pressure, allowing the wheel to once again regain traction.
Aside from this system’s ultra-fast response time, it offers a number of additional sport-riding benefits, including rear-end lift suppression during hard braking, minimal kickback during ABS intervention, and increased rear brake control during downshifts. The high-precision pressure control enables the system to avoid reduced brake performance (sometimes seen on less advanced systems), maintain proper lever feel and help ensure the ABS pulses are minimized.
The rest of the 2012 Ninja ZX-10R ABS is equally advanced. Complete with a powerful engine and lightweight chassis, it also boasts a highly advanced and customizable electronic system that allows riders of all skill levels to harness and experience the ZX-10R ABS’s amazing blend of power and razor-edge handling. The system is called Sport-Kawasaki Traction Control.
Motorcyclists have forever been challenged by traction-related issues, whether on dirt, street or track. Riders who can keep a rear tire from spinning excessively or sliding unpredictably are both faster and safer, a tough combination to beat on the racetrack. And when talking about the absolute leading edge of open-class sport bike technology, where production street bikes are actually more capable than full-on race bikes from just a couple years ago, more consistent traction and enhanced confidence is a major plus.
Key Features
• Engine and chassis allow for linear power delivery
• Sport-Kawasaki Traction Control (S-KTRC) continuously monitors wheel speed, throttle position, engine rpm and a host of other data to help ensure the optimal amount of traction
• Advanced Kawasaki Intelligent Anti-lock Braking System monitors a wide range of data, and allows optimum wheelspin while enhancing rider control
• Power Mode selector allows riders to select power level and power delivery
• Aluminum frame has ideal strength and rigidity
• Big Piston Fork (BPF) helps maintain composure under braking
• Horizontal back-link rear suspension helps deliver smooth suspension action
• Slipper-type back-torque limiting clutch helps corner entry handling
• Race-oriented instrumentation offers riders a wealth of information
2012 Kawasaki Ninja ZX-10R ABS - Specifications/Technical Details
Canada MSRP Price: See Canadian Kawasaki Dealer for pricing.
US MSRP Price: $14,999.00 USD
Type 4-stroke, In-Line Four
Displacement 998cc
Bore and Stroke 76.0 x 55.0 mm
Cooling Liquid
Compression Ratio 13.0:1
Valve System DOHC, 16 valves (4 valves per cylinder)
Fuel System DFI with 47 mm Keihin throttle bodies with oval sub-throttles, two injectors per cylinder
Ignition Digital TCBI with S-KTRC (Sport-Kawasaki TRaction Control)
Lubrication Forced lubrication (wet sump with oil cooler)
DRIVETRAIN
Transmission 6-speed cassette, with positive neutral finder
Final Drive Sealed Chain
Primary Reduction Ratio 1.681 (79/47)
Gear Ratio: 1st 2.600 (39/15)
Gear Ratio: 2nd 2.053 (39/19)
Gear Ratio: 3rd 1.737 (33/19)
Gear Ratio: 4th 1.571 (33/21)
Gear Ratio: 5th 1.444 (26/18)
Gear Ratio: 6th 1.348 (31/23)
Final Reduction Ratio 2.294 (39/17)
Clutch Wet multi-disc, manual
FRAME
Type Twin spar, cast aluminium
Wheel Travel: Front 120 mm (4.7 in.)
Tire: Front 120/70-ZR17
Wheel Travel: Rear 140 mm (5.5 in.)
Tire: Rear 190/55-ZR17
Caster (Rake) 25º
Trail 107 mm (4.2 in.)
Steering Angle (Left/Right) 27º/27º
SUSPENSION
Suspension, Front 43 mm inverted Showa Big Piston front fork with top-out springs, stepless compression and rebound damping, fully-adjustable spring preload
Suspension, Rear Horizontal Back-link with gas-charged shock, piggyback reservoir and top-out spring, stepless, dual range (high/low speed) compression damping, stepless rebound damping, fully adjustable spring preload
BRAKES
Front: Type Dual semi-floating 310 mm petal discs, 10-button aluminium rotor carrier
Front: Calipers Dual radial-mount, opposed 4-piston
Rear: Type Single 220 mm petal disc
Rear: Calipers Single-bore pin-slide, aluminium piston
DIMENSIONS
Overall Length 2,075 mm (81.7 in.)
Overall Width 715 mm (28.0 in.)
Overall Height 1,115 mm (43.9 in.)
Wheelbase 1,425 mm (56.1 in.)
Ground Clearance 135 mm (5.3 in.)
Seat Height 813 mm (32 in.)
Curb Mass** 201 kg (442.9 lbs.)
Fuel Capacity 17 litres (3.7 gal.)
Fuel Consumption 5.8 L/100 km (49 MPG)
** Includes all necessary materials and fluids to operate correctly, full tank of fuel (more than 90% of capacity) and tool kit (if supplied)
PERFORMANCE
Maximum Power‡ 131.7 kW {179.1 PS} @ 11,000 rpm
Maximum Power with Ram Air‡ 138.3 kW {188.0 PS} @ 11,000 rpm
Maximum Torque‡ 112 N.m {11.4 kgf.m} @ 11,500 rpm
‡ Power / Torque figures measured at the crankshaft.
Key Features
Displacement 998cc
Cooling Liquid
DRIVETRAIN
FRAME
Caster (Rake) 25º
SUSPENSION
BRAKES
DIMENSIONS
PERFORMANCE
