2013 Harley-Davidson Breakout CVO: Voted Awesome
Posted: Fri Aug 24, 2012 3:42 am
2013 Harley-Davidson FXSBSE CVO Breakout on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... eakout.htm
Slammed and chopped style goes premium in this all-new CVO motorcycle. From stunning details and finishes to brawny power, the only thing low about this sport custom is its silhouette.
The 2013 Harley-Davidson® CVO Breakout motorcycle is muscle in motion. This new, limited-production Softail® model from Harley-Davidson® Custom Vehicle Operations combines the unrelenting power of the Twin Cam 110B engine with a level of custom detailing that is unmatched on a production motorcycle. Curbside, the Breakout motorcycle rests with a proud rake and dazzling finish. On the road, the CVO Breakout motorcycle is a chrome-plated fist punching the air with each twist of the throttle.
Harley-Davidson® CVO motorcycles are customized using exclusive components and paint trea ents combined with numerous items from Harley-Davidson® Genuine Motor Accessories. The CVO Program is often used to introduce new custom components and techniques before they are offered as individual accessories.
The Breakout motorcycle is intended to project a tough attitude, according to Harley-Davidson Motor Company Styling Manager, Kirk Rasmussen.
"We begin by stripping the bike down to the bones and building up from there," said Rasmussen. "Stylist, Mark Daniels, penned a tough-looking hot rod concept and we were off to the races. To create a compact, muscular profile we've chopped the fenders to the legal limit so more tire rubber is revealed at both ends of the bike. The same principle is applied to the console, where we shaved it down and used braided steel lines for vent tubes. This gives us a larger canvas for paint and finishes, an essential element of the CVO formula."
The CVO Breakout motorcycle's story begins with its Twin Cam 110B engine, a 110-cid V-Twin that pumps out 112 ft. lbs. of peak torque to give the CVO Breakout motorcycle the best power-to-weight ratio of any current CVO model. The CVO Breakout motorcycle takes production motorcycle paint to a new level of true customization. Two paint schemes feature hand-polished steel sections on the fuel tank and fenders. A third paint option incorporates hand-laid lace stenciling. The amount of manual finishing required to create these painted parts makes each set of bodywork unique.
New polished chrome Turbine wheels are another styling highlight to debut on the CVO Breakout motorcycle. "We gave the Turbine wheel a good deal of drama by pulling the spoke ridges all the way through to the rim, which help make the wheel diameter look larger," said Rasmussen. "The front wheel has 21 spokes. I think the ridges on the rear wheel look a little scary. The dramatic diameter of the 21-inch front wheel with a 130 mm tire and the 18-inch rear wheel with a 240 mm tire give the bike a strong proportional foundation."
Other custom details introduced on the CVO Breakout motorcycle include a wide front end with a mini headlamp nacelle, and a chromed cast-aluminum oil tank. The Softail® chassis mimics the clean lines of a vintage hardtail frame, but utilizes rear suspension control provided by coil-over shock absorbers mounted horizontally and out of sight within the frame rails. Electronic cruise control, Anti-Lock Braking System (ABS), keyless ignition, and the Harley-Davidson® Smart Security System are standard equipment on the CVO Breakout model.
2013 Harley-Davidson FXSBSE CVO Breakout - USA Specifications/Technical Details
US MSRP Price: Custom Color Option $26,499
Canada MSRP Price: $ 30,099
DIMENSIONS
Length 96.3 in.
Seat Height, Laden 724.8 in.
Seat Height, Unladen 725.8 in.
Ground Clearance 4.2 in.
Rake (steering head) (deg) 37
Trail 5.7 in.
Wheelbase 67.3 in.
Tires, Front Specification 130/60B21 63H
Tires, Rear Specification 240/40R18 79V
Fuel Capacity 5 gal.
Oil Capacity (w/filter) 3.5 qt.
Weight, As Shipped 698 lb.
Weight, In Running Order 728 lb.
Luggage Capacity -Volume N/A
Luggage Capacity -Weight N/A
ENGINE
Engine 1Air-cooled, Twin Cam 110B™
Bore 4 in.
Stroke 4.38 in.
Displacement 110 cu in
Compression Ratio 9.2:1
Fuel System 3 Electronic Sequential Port Fuel Injection (ESPFI)
DRIVETRAIN
Primary DriveChain, 34/46 ratio
Gear Ratios (overall) 1st 9.311
Gear Ratios (overall) 2nd 6.454
Gear Ratios (overall) 3rd 4.793
Gear Ratios (overall) 4th 3.882
Gear Ratios (overall) 5th 3.307
Gear Ratios (overall) 6th 2.79
CHASSIS
Exhaust Chrome, shorty-dual exhaust w/ slashdown chrome mufflers and chrome heat shields
Wheels, Optional Style Type 9 N/A
Wheels, Front Type 9 Mirror Chrome Turbine Custom Wheels
Wheels, Rear Type 9 Mirror Chrome Turbine Custom Wheels
Brakes, Caliper Type 4-piston fixed front; 2-piston floating rear
Parking Brake N/A
PERFORMANCE
Engine Torque Testing Method J1349
Engine Torque 112 ft-lb
Engine Torque (rpm) 3,500
Lean Angle, Right (deg.) 25.3
Lean Angle, Left (deg.) 26.2
Fuel Economy: Combined City/Hwy 45 mpg
ELECTRIC
Lights (as per country regulation), Indicator Lamps 8High-beam, neutral, low oil pressure, turn signals, engine diagnostics, security system, 6-speed, low fuel warning, cruise control, ABS
GaugesNew- 4 in. Combination Digital Speedometer / Analog Tachometer
DIMENSIONS
Length 96.3 in.
Trail 5.7 in.
Wheelbase 67.3 in.
ENGINE
Bore 4 in.
Stroke 4.38 in.
DRIVETRAIN
CHASSIS
Parking Brake N/A
PERFORMANCE
ELECTRIC
