Page 1 of 2
bike dies after 20mins of riding
Posted: Tue Apr 30, 2013 11:10 pm
by neverdie38
1981 cm400A. new piston rings, new plugs, carbs clean, pod filters, straight pipe exhaust (rejetted with 78 and 138), good fuel and oil w filter. the bike will start right up and run AMAZING but after about 20mins of riding it will have no power, won't go above 40mph, and won't idle. doesn't matter if you are riding steady or doing stop and go in town. it has plastic floats so i can't adjust fuel level. after it starts acting up i pull over and there is a little white smoke coming from around the spark plug. all i have to do is kick it and give it throttle and it will run but it has no power and won't idle. if i let it cool down for a while it will start back up and run like a champ again. is something electrical getting hot?
Re: dies after 20mins of riding
Posted: Wed May 01, 2013 2:15 am
by Johnj
Check your fuel tank vent.
Posted: Thu May 02, 2013 11:15 pm
by neverdie38
i rode without cap yesterday. went 14.2mi (about 23mins) and it seemed to do fine. even let it idle in garage for 2mins. thank you very much. i never would have even guessed that was an issue
Posted: Tue May 07, 2013 2:10 am
by sapaul
@JohnJ, you da man
Re: bike dies after 20mins of riding
Posted: Thu Jul 04, 2013 5:22 am
by neverdie38
it still dies a little bit. i think it's getting too lean and hot while riding. i adjust the idle screws out (it has open exhaust and pods). i even applied rubber sealer around pod boots to make sure it wasn't sucking air where it shouldn't. could the lean condition cause it to get hot and then shut down?
Posted: Thu Jul 04, 2013 6:20 am
by Johnj
If it has open exhaust and pods on it, it needs to be rejeted.
Posted: Thu Jul 04, 2013 8:31 am
by BRUMBEAR
for care and giggles check your valve adjustment if applicable.
Posted: Thu Jul 04, 2013 11:45 am
by neverdie38
i did re jet it. think my main could be one size bigger though. i will check valves soon, it's been on my list
Posted: Sun Jul 07, 2013 7:20 pm
by Wrider
What's the stock jetting and what altitude are you at?
Posted: Wed Jul 17, 2013 6:59 pm
by Bizmal
Are the straight pipes new to the bike?
